  • Replies 101
I think it had forgies, not sure. Once he put a set of roller rockers in it it went a lot better.  He wanted some Yella Terra alloy heads but said it wasnt worth it on a 10A.
Whats in your FC,  i like old Holdens...still three on the tree?
My FC is stock.....See you at calder dude, talk is for the weak.
Talk is all i got mate. If i shift my auto manually and stall it up i should be able to break into the 14s...LOOL...this is fun...i havent talked this much sh1t in... in...well it must be hours surely:)
But seriously, have always thought drag racing is too brutal on the car, but just curious to see how the old girl goes, plus want to try a few new things on the car. No more dribble from me... i probably have you worried:)
My car is 5spd manual, isnt yours too :D
Come on, your clutch wont explode.. or will it :Paranoid:
Sh1t...110mph on 5psi...im sure its running the std turbo then:(
In all seriousness if i can get a low 13 or high 12 ill be stoked. I doubt i will though as i dont like launching hard in the car, probably the reason the car has been as reliable as it has over the years:)
Your cars been off the road for long nough, why not just extend that period by blowing the sh*t out of you box!!!
The=n you can take it back to ICE to build a new one out of three old ones they have, that they don't know if it'll work or not..... j/k :spcow:
This is why I have stayed away from drags (Except on the street) at Calder etc. I like the idea of testing your cars power to weight in a straight line, but there are just way too many tools out there. St.Albans style di*ks with an arrogant attitude towards new people. I much prefer the enjoyable track days where everyone can give it a go and we can encourage newbies to join.
I'd like to go down to Calder with you Troy, but we may have to just keep to ourselves.
Come to PI in a fortnight...lol we will help peel your car off the wall when you realise that drag racing is for mummy's boys... throw some big stops and turns into the mix and dra queens go to water:)
:werd:
Just like a drag strip only you have to actualy turn at the end once you hit 200+ k/m :P
Yeah one day I want to give this a shot (if only so I can answer everyone when they ask what my car does down the 1/4! LOL) but until I get 2nd gear fixed I'll have to pass up.
But I'll try to come down for a look and to cheer you on Roy. Just don't break the car again before PI. Actually, you sure you don't want to wait til AFTER PI before you try this mate?
Red...your car sounds tasty... any details. Massive brakes? Cool!..110mph? Cool! Is it a 15yr jap jobbie, modded local delivery?
I like Series IV/V RX7s, almost bought one but where i lived at the time stopped me as the locals would have stolen it in a matter of weeks:(
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
