GTR-Ben and BHDave, Thanks for the great advice guys! Really helps clear things up for me when you guys take the time to type out the above. We should get some sort of 'Virtual Beer' credit setup on SAU so i could shout these lads a beer for their efforts!
Just a couple more questions
1. What is the SMJ?
2. What type of adaptor did you use for the heater hoses?
3. What is an EGR valve?
Sorry I didn't finish guys.. lol
SMJ = Super Multi Junction. Thats the big plug by the ECU on the Rb25 rather than have several small plugs like the R32.
EGR = Exhaust Gas Recirculation. I think he means the ACC valve?
Heater hose adaptors.. $5 ones from repco will do it. The size of the RB25 is large 19mm or so where the R32 size into the firewall is 16mm or so.
Now for the wires.. I didn't hook up A/C as there was none.
In the R32 engine bay there are 2 plugs by the passanger side headlight.
You use 3 wires from one of them only. The other plug is for an Auto.
The 3 wires on the R32 are (Black/Red, White/Purple, White/black) the 2 large ones, are for the power to relays etc, the White/Black is power to sensors etc.
Now in the same location there is a single plug that runs from the RB25DET. From this it is only the grey wire that is spliced into the Black/White on the R32 plug. This is power for the injectors.
Under the dash at the SMJ you need to run 3 good sized wires up to the 3 in the engine bay on the R32 plug.
There is a Red/Black, Red and a Black/White
R33---------------------------R32
Black/Red---------------->White/Purple
Red------------------------>Black/Red
Black/White-------------->White/Black. (has the grey injector wire also attached to it.)
This is all that is needed for the car to run.
Now you just need to attach water temp, fuel pump relay and tacho under the dash.
On the R32 under dash loom there are two plugs. The colours are similar.. you need to use the ones on the smaller or the two. 14pin. The other has 18.
R33----------------------------R32
Blue/Black ---------------->Blue/Black. Water Temp. ( you also need to use the RB25DET engine sender. (single wire)
Yellow/Blue---------------->Yellow/Red. Tacho
Black/Pink------------------>Black/Pink. Fuel pump.
Ok I think thats it... Beer credits would be good. :)
I may have missed something.. i'm sure others can fill any holes.
Ben
When i talk about the egr i mean the second valve on the plenum that is effectively an anti stall for when the car is cold (or so i have been told). Also found out today that the second plug going to the aac valve on the rb25 is supposed to be triggered by the AC on to step up the idle speed rather than having the other side of the aac compensate as in the r32.
There are a couple more wires in the under dash plug that you may want to hook up but they are not esssencial. These are the fuel pump speed control, exhaust temp light, engine check light, ac on input, and the consult CHK, TX, CLK and RX and i think, though i'm not 100% that the earth and power for the consult plug are connected in here too.
In the big plug at the front i have found that the ac relay trigger wire and power steering idle up trigger are in it as well as the neutral switch to ecu input and injector power that ben mentioned.
And then you need to run 3 wires for the constant power and switched power for the ECU and switched power for the ignition relay as ben stated.
My r32 actually has the same big plug in the front corner as the r33 loom but earlier models that i have worked on have a 4 pin with the main power and power steering idle stepper.
  • 5 years later...
Hey guys, ive just done a RB25de conversion to my R32 GTST (P Plate Laws), Im Having trouble with Wiring, i have the RB25 loom and computer running, There is a 6 Wired Plug on the RB25 infront of the plenim, this plug runs intop the dash on the R33, What is it? is there any way i can by pass it? Thank guys
  • 2 years later...
Ben
thanks a sh1t load for this info been looking for ages now trying to figure it out,with the water temp sensor on my rb25det in my r32 i still cant seem to get it to work when connecting the wires you have advised,ANY other ideas :cheers:
g'day im looking at doing a rb25det conversion from a r33 s2 into my r32 gtst and using a rb25 wiring harness. Is there much of a differenence in the harness from s1 to s2? Can someone directly experienced with this conversion help with a detailed wiring conversion? muchly appreciated
hay fella iv movd on from the skyline and the s1 25t,now in middle of this s2 25t into a31 cefiro convertion (WIRING SIDE) and trying to nut out what is wat as it is diff from s1 loom.i will put up info as i find out,will be slow :( but will work,UNLESS sum1 1 can line us up with a guide to the power up wires and how what colour they are.
the power wires for the 25det are wer the cefiro rb20de power wires are (ECU POWER IGN PWER) just next to pwer steering pump and resovior,now i can see to find the aac and the power to injecters wires.so im at this hump at this moment,
PS this site is so fkun helpfull honestly im in the wopwoops in NZ and no ! knows nuffn apart from here say sh1t :worship:
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
