track/drift day saturday January 15th $150bux
Thanks Fatz,
Had a top day... is a good challenging few corners for drift, Nice and long. And to think I was going to behave myself and just drive in the lapping group... pfft!
Thanks Neil mate, was a big shame that we couldn't get that thing of your going for more than 4 bloody laps, but look at it on the bright side, at least you made it worth while for the truck driver!!! :)
Dan.
  • Replies 372
thanks pete for organising the day was sweet as, i found it a bit hard to keep speed up enough to get to second corner. but i got the second and third corner linked about 2 times still learning :)
thanks to Mal and Dan for taking me out as well. was great to get to experience drift from the passenger seat.
i must of left before the acco at the end. looks pretty rough!
cant wait to see the footage from Dan's "rear wheel" camera!!!!
cheers
Jase
also why the blanked out number plates? just in case big brother was watching????
Unlike most of the cars there, I did not want to have any warranty issues later on. Car makers and insurance companies often have spy's at the track days taking happy snaps for use later on.
Who said Ford's cant Drift......I had the best track day ever.....Pete, when is the next one :wassup:
Great day, i struggled alot with understeer in the drift sessions, i've never had my understeer much at all before but it's the first time i've been somewhere big enough to drift higher than second gear. I did some playing with camber and tyre pressures which seemed to help me a little toward the end of the day. I was in the blue gazelle with gold on it by the way.
As for the crash in the drift it was my mate in the two tone gazelle that hit fernando in the gold sileighty. 4 cars were drifting in a row with fernando first, he spun and the 2nd and 3rd cars dodged left and right, my mate in the gazelle was still broadside and tried to spin and miss him but ended up hitting him going backwards. Thats drifting for you though.
I didn't have such a great day ,,,but hey I got to catch up with all you drop kicks which made my pain easier. It pleased  me greatly to see Dan get on pace so quickly. 1st session buddy you were on it. I was also pleased to see the counrty boy hold out that crapy Mini,,,well done mate.
All in All I think SAU had a great day.
Thank Fatz.
P.S. I'M PISSED
Neil.
Cheers, No way I'm letting a mini past the mighty RB20... :P Four hour drive well worthwhile. Thanks Fatz. I'm in next time.
As far as i could tell with the drift crash it wasn't really anyones fault. The 4 cars were drifting as a group and the first one spun, the last guy really didn't have anywhere to go (the other two only just missed the spun sileighty anyways). The two drivers talked later and it seemed cool. The damage was probably about equal to the two cars but the S13 looked much worse.
great to see so many SAUers out there giving it a go, and also that all of us made it home without real incident.
esp well done to the wagga boys for making the effort :(
Pete, I hope you'll be able to ditch some of those driftland bookings and move them to the south circuit again, that was a great mix :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
