track/drift day saturday January 15th $150bux
Or ARM85 you could pop around to my place, pick up a set of my old rims (I've got 6) and take them for shitty tyres.... seeing as how I live in Wagga and all...
We are going in convoy, yeah?
Also, I'd like to know where my stickers and card and stuff are... I want my discount!!!!!! :ghost:
  • Replies 372
the figure 8 is the north circuit
south circuit is about 4 times the size and has a straight you can get up to about 180km/h on
currently about 30 people going
the pland for the day is turn up at 8
sign up have a chat
on the track by 9
30 minutes circuit
30 minutes drift
untill about 1230 then 30 minutes for lunch
the the same again till 5
track time will be huge
mm 31s will represent. so far:
- RB25DET GTS2 Replica (kyle)
- RB30ET Wagon (anthony)
- SILHOUETTE & GTS-X (me)
- SILHOUETTE & GTS-X (pete)
- GTS-X (chris)
- SILHOUETTE (big ed)
mmmm sirty one sirty one
keep an eye out for the grey on silver silhouette burnout machine hehe
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
