  • Replies 52
The RTA says 15mm change is ok in the overall tyre and rim combo, BUT every dumb ass coppa i've been defected by says, "1inch higher, 1inch wider ONLY"
I think he was talking about his man hood. Go stick a 350z tyre placard on the car, problem solved as these only say Nissan on them.
Read the document in your first post. These are the ones that apply to you:
An important requirement for all replacement wheels is that the wheel track must not be increased by more than 25mm beyond the maximum specified by the vehicle manufacturer for that vehicle.
Wheels up to 26mm wider than the largest optional wheel recommended by the vehicle manufacturer for the vehicle can be fitted without the need to notify the RTA.
The outside diameter of the wheel and tyre combination must be no more than 15mm over the largest diameter wheel and tyre combination specified for the vehicle and not more than 15mm below the smallest diameter wheel and tyre combination specified for the vehicle.
and
• The wheel and tyre must be contained within the body work or mudguards (including any flares) when the wheels are in the straight ahead position.
• The wheel and tyre must not foul any part of the body or suspension under all operating conditions.
• Speedometer accuracy must be maintained for the selected tyre and rim combination.
• The fitment of wheel spacers (or adaptors for dual wheel conversions) between the wheel mounting face and the road wheel is not permitted unless fitted as original equipment by the vehicle manufacturer.
So... as has been mentioned previously, as long as the overall rolling diameter of the wheel/tyre combo remains within 15mm of stock (by putting lower-profile tyres on bigger rims, which you'd do anyway), you don't go more than an inch wider in the rim (any sized tyre is fine, as long as it fits on the rim safely), and you don't make the track more than 26mm wider than stock, you're fine.
Why the confusion? You put a link to all the answers in your first post!
All of the answers are there in black and white, people's life stories have nothing to do with your not reading the document properly.
If you're still worried, get the sizes of the wheel/tyre setup you want, and contact an engineer (or "signatory" as the RTA document refers to them). They'll tell you for sure if the wheels and tyres adhere to the rules in the document, and if they don't, but they deem them to be safe, they can issue you with an engineer's certificate, which makes them legal anyway.
lol mate im not the immature one thats getting cut over a forum
mature is not about being rude
maybe i missed a few things, maybe i like to speak to my mates on a forum
i didnt ask 4 your negative input.
heres a "mature" quote for you buddy
"better to remain silent and be thought a fool than to speak out and remove all doubt"
Point to the bit where I was rude. All I did was offer advice and say:
In other words, re-read the document and you'll have your answers.
I fail to see how interpreting the document you were too lazy to properly read (and providing you with an answer to the question you asked) is negative input. I have not picked on you for talking to your mates on a forum.
Maturity is a lot more than cutting and pasting quotes... and perhaps you should take your own advice.
Finally, here's a pic of the tyre placard.
As you can see, it's clearly labelled Nissan Skyline, it is also very thick, and shimery. To me it looks and feels real. So to Police I'm sure it would look and feel real to them too. Besides, I don't see why it would be a fake.
One thing though... I have 235/40r18 on 18x9's... The placcard suggests I should have bigger tyres?? If I did they would scrub... meh. All good.
wil..
What was the "largest optional wheel" recommended by Nissan for the R32 GT-R? Obviously it came with 16x8s, but the wording seems rather dubious to me as it suggests it is based on what Nissan recommended as the largest size (ie. on the tyre placard)?
Lucien.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
