Some times I take off in second as I find it quicker to get out in front of traffic. :D
Have a read of the thread in Forced Induction.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=55503
I've been muttering to myself a little but I've came to understand the issue I've had on the stock ecu.
Exhaust Reversion.. :)
I'm running N/A cams and a stock turbo (rb20t). The N/A cams have a decent overlap that with the high manifold back pressure causes exhaust reversion when coming on to boost (where exhaust reversion is noticed the most).
Only way out is a set of adj. cam gears, different cam and or a larger turbo.
The 3ltr is the way to go though. Make sure you select the right pistons to keep that factory .045-.050" squish otherwise you will drop in economy instead of picking some up. The rod angle of the 3ltr with the right squish "should" provide a more efficient engine.
  • Replies 49
I used a ryco when cycling my oil.. Hopefully it stopped all the stuff.
I was at UAS the other day so I picked up a JIC oil filter (j-brand) so we'll see how that goes - good idea about cutting it open I never thought of that (duhh).
Will let ya guys know what it looks like (although I must admit my oil is a better colour than when the ryco was on it).
For those who are interested in buying Amsoil oil filters, I spoke with Bruce and for Melbourne area people you can go to;
Lubrication Management Systems
127B Lonsdale St
Dandenong
(ask for Bill Reid, top bloke)
Now, as for me, Geelong has an Amsoil distributor;
Zoom Master
31 Barwon Tce
Geelong
(ask for Kevin)
There are 2 main oil filters for the RB25DET, SDF15 & SDF34. The SDF34 is the recommended one, but the SDF15 will fit and is almost an inch larger, has the exact same filtration properties (10-15 microns), 7-9psi pressure dif valve, retention valve, etc.
I'm going to head down next week to Zoom Master and just make sure the SDF15 fits.
PS. For those maybe wanting to do a group buy, Bill said he'd do a good price, I just can't be farked!
:P ... Kyran
  • 1 month later...
I just pulled apart a cooper. I went to autobarn to get some of the $3 specials a while ago and the guy said be very careful with them as a friend stuffed his motor when some paper came loose. I have used them in the family cars for the past 3-5 years no worries. He reckoned change them every 5k saying the rycos are better.
I read an article on the net praising the coopers but wanted to see for myself.
This one here has been in the gfs 91 model corolla for 10,000kms with oil change at 5,000 kms. (Engine has 220k kms on it). Oil filter shown is Z386 - for skyline it is Z145a, but I assume all coopers are of a similar standard.
Things to note. There was plenty of oil still in the filter which means the anti drain back valve was still working fine. You can usually tell this by the weight (comparing to new filter)
The can and spring (spring is to keep pressure on the Anti drain back valve
The parts - from left, paper filter, case, spring, Anti drain back valve
By pass valve at bottom, cannot see too well. You can se the little holes to allow filtered oil to flow through to the centre section.
Paper filter
I have new Nissan and cooper oil filters at home. On visual inspection the holes shown in the 3rd pic are larger on the coopers than the nissans, probably not a great thing as if the paper did give way then more chance of a larger piece making its way into engine. I have 2 coopers for a corolla at home and it seems the newer coopers have larger holes whereas older ones had more smaller holes. Don't know why they changed, probably not a big deal at all. After 10000kms the paper was still pretty firm and didn't appear as if it would give way. It didn't tear really easily.
I'm going to stick with the coopers. Never had a dodgy seal either whereas I've heard people with Rycos having probs.
  • 4 weeks later...
Now that I'm due for another change of oil filter (oil leaked out + new sump + new oil) other than having to trek to UAS for a JIC filter (which seemed to keep my oil a nice consistency/colour) are there any other brands to try?
Ryco I'm not impressed with (have heard too many bad things). Paper filters I'd rather shy away from if possible.
Does anyone else know of any good brands or recommend anything? What do all the track hounds use?
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
