  • Replies 76
yup.... ive mentioned it earlier in some other thread.... somewhere....
There taking my licence... Just because of a little slip of the rear slightly to the side..
Very pissed off, and really lost in what to do..... i cant live without driving my baby.
Dunno what ill do, i wont be able to cruise past your skewl just as the bell goes anymore :)
A.C.T. FORECAST:  For the rest of today and Saturday
Rain periods easing today with a possible afternoon thunderstorm and northerly
winds becoming fresh and gusty.
Should clear up this afternoon but stay cloudy and maybe an little bit of a shower tonite so I want to see everyone out still :D
how many points were taken? is it contestable? more info Andrew.
Well i lost 1 point when i first got my licence from one of thoes van things....
and this guy took 3 points off me, which now equals 4points... although just after i got the fine i went and did the P OFF course and got another 4 points... so thats all ive got to fight with
When i lost my licence the time flew by. 3 months isn't as long as you think. it was a pain in the arse having to catch the bus to school again, but you end up with full points again. I think thats better than having to granny around with 1 or 2 points for 3 years
so hang on youve done the p off course, and your wondering if you can still keep your lisence? thats what i got from what u said anyway, if that is the case then your fine!
i lost all four of mine in 1 hit gassing down drakeford in my old lancer. so i did the p off course 2weeks later before i paid the fine and i have 4points again, how long till you get points back after losing them though? doesnt matter really anyway, i will have my full lisence in 6months.
haha andrew, we dont have a bell :). why do u cruise past neways??
Well...... i.........ummm...........dont really........... :Oops:
Yea well i did my P Off course a couple of days after i got the fine, and then 2-3months later i paid the fine... Now they send me a letter saying ive lost all my points. WTF??!!
They closed that loophole, one of my mates did that a couple of years ago, and didnt lose his license, but then another mate did the same a couple of months ago but has now lost his license
skyline gtr its like this
start off 4 points. do p off course + another 4 if you have definatly completed the p-off course and you have lost only 4 points ring up the p-off course and clarify they have let the RTA/police know about the extra 4 points as by the sounds of it you still have 4 left :)
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
