hahah that was sooo funny... then we got him to yell out "dan the man rules" :( over all i think it was a great night.. so many adventures and just chillin inthe grandstand was hella cool.
Thanks to Liz and Dan for hanging out with us :) and nice to see you again lauren. and nice to meet u melki and adrian :(
Break It Down Now!!
  • Replies 416
a siikass of a night!!!
Checked out all rooms early then hung around the middle-ish area of the main room until around 6am then checked out the rest of the rooms again, only to find adrian_perth gurning it out in the drum and bass :cheers:
Man did Ferry's set go off or what? especially when he played his classics, Punk and ROck Your Body Rock... that was absolutely awesome!
Nice to meet u Niz and Melki ;), hope to meet the rest of u's soon ^^/
I went totaly nuts to 'Punk' and 'Rock Your Body' was aiting all night for them to play, i as outside on the stadium when 'Punk' started, was pretty crazy sight seeing basically the whole audience in the stadium pick and and move inside to listen. And then 'Rock Your Body' came on directly after wards, total highlight of the night.
Luv'd seeing a strobe light go off and a good song come on, 1000's of people put the hands up and start jumping.
Its insane.
:jump:
:rave:
I like repeditive music, I like repeditive music,I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music, I like repeditive music -Regurgitator :cheers:
The Panics are good ;)
Had a great time :) Saw Adrian, Petie pie, Lozzle, Tigeryas, BamBam, Liz n Dan, Boosty n Denish, Denver ...... to those i missed damn! :)
Had a great time .... spent a lot of it upstairs hanging out with Mel, Josh n Darrens funky clone. Tao's remix to Smells like Teen Spirit went crazy :crazy:
Pulled up fine Sunday morning ..... then got a bit pissed on sunday night and now i feel dizzy and shite .... so today at work will be interesting.
Hey mel ...... foreeevver young ... i wanna be foreeever young :D *rofl*
was wicked fun! outside was such a nice night.. funny watching the volleyball.. bring on bikini's! they rock.. got so hot so ripped off shirt and ran around with a glowing green bikini top on.. felt so much better after that.. :)
was good fun night. nice change from metros and monkey bar :)
adam f goes off!!! :D
well i had a ball runnin round with my lil sis and a few old rave buddies i met along the way mr lion was a hit with the ladies involving many hugs for both of us bring on cute backpacks tunes where great as you would expect for a belmont rave and the atmosphere was brilliant good ta see perth can still bring it for the big ones
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
