Judge Reinholds Back!!!!! where ya been???
Yeah maybe you could grab a certain image of the supra instead.... I took photos with my crappy strathfield camera at the time....
I remember the video with PVA's commentary: Oh sh*t Sh*t he's f*cked it, it's sh*t oh F*ck sh*t ****! HAHAHA ...... now thats somethin only us old schoolers can relate to.... all these young whipper snappers on the forums these days, I can remember the old Judge Reinhold drifting supra days! ....
Hmmm one of my friends though was lookin for a thrash mobile.... can ihave some details? WARNING i hope you don't have any emotional attachment ie 1st time in the back seat kinda thing because beleive me i don't think it will last long the way he drives bu he does need a bunky.... i just think hes jelous over my bunky old ford lazer.... ole reliable shezza
commentary went something like this:
pva "Don't stop man don't stop just keep going!"
pva's friend driving "You gotta stop man, hes f**ked his f**kin car up!"
haha i got an awesome :whatsthat photo, not taken by myself though
you look pretty excited dude
Hehe i always look like that, not the greatest photo in the world, i look kinda crazy. Cheers though Boost.
Details in the performance forums for sale sect. How come SAU has no for sale sect anymore? well they do but i dont seem to be able to post in there.
Yeh i do have an emotional attachment to it so im only gonna let it go to a good home. Its the only one of its type in perth so its almost a classic i reckon. Dont want some noob crashing it.
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
