easier and cheaper to buy a gtst than convert a gts, you'll have to change the brakes/wheel hubs to 5 stud, which also means new wheels etc... and get it engineered, and i think most people just swap the whole engine for a gtst one rather than mess around with the N/A one, so probably not as cheap as you imagined.
you don't need to change the wheels/brakes etc etc etc
easiest way:
manifold
turbo
intercooler (optional)
injectors (optional)
fuel pump (optional)
BOV (optional)
electronic boost control
boost gauge
other shit i left out :D
all you do is change the manifold, put turbo on, get lines etc etc done, add other shit if you want like FMIC. Set bosot to ~7 PSI max - as your compression will still be too high to run high boost....
if you want to go all out engine swap RB25DE for DET - half cuts cost few grand, but keep in mind GTS gearboxes are weaker - so you'd need to do the lot if you wanted to run 15+ PSI and expect your vehicle to last :D
cheaper to buy one in the first place - but not as fun :D
i dunno i reckon an rb30 bottom end conversion would be tops as for it, as the gts n/a would be cheap as to get and you can get the rb30 block for like $300. then do a 25/30 conversion on it, 3.0 block 2.5 twin cam head with turbo manifold would be a monster the rb30 howto even says to use the n/a 2.5 head and change the brakes
i wouldnt keep stock r33 gtst brakes on an rb30 conversion so it doesnt apply you could just get slotted and drilled rotors from dba (dba4000) and youll have to upgrade clutch and other shit if you did it in a gtst anyway so its no diff really, just a cheaper base car. the stock gtst clutch/brakes/cooler wont take the torque of the rb30, well it well just very badly and not wise. rb30 gt340 highmount it would be an absolute killer i think the stock rb30 with the r33 turbo winds up boost from like 1300rpm or something stupid, whereas stock r33 gtst hits 7psi at about 2500rpm (well mine does) or just a tiny bit over 2600rpm maybe
something to consider
rb30 should set you back around 4-5k ? check out the rb30 howto
  • 1 month later...
you already asked this in the forced induction area. i believe the na head will fit but it has different injectors and head gasket, it will work you wont be able to go over 5-7psi safely as the compression is different between the turbo and na head. to run 12psi youll need to change injecotors and gasket to change compression ratio as far as i can recall there was a better answerr in the forced induction area
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
