akeenan Posted November 11, 2002 Share Posted November 11, 2002 The best results can be achieved only after the computer has been reset and it learns a new fuel/timing map! yes thats what I was going to remind everyone to do reset ur batteries! Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-89523 Share on other sites More sharing options...
Guest INASNT Posted November 11, 2002 Share Posted November 11, 2002 Originally posted by MegaGTS4 Brody, The best results can be achieved only after the computer has been reset and it learns a new fuel/timing map! MEGA I still dont believe reseting the comp does anything as the comp is consistantly getting info from the sensors and learning! Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-89659 Share on other sites More sharing options...
MegaGTS4 Posted November 12, 2002 Share Posted November 12, 2002 INASNT, I could explain it to you but its better explained in these two links! http://www.overflow.250x.com/tips.htm#reset (Dyno graph after ECU reset) http://www.skylinesdownunder.co.nz/tech/ecu_reset.html MEGA Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90185 Share on other sites More sharing options...
Neil Posted November 12, 2002 Share Posted November 12, 2002 I've been told the mesh is there,,,,not only to stop any crap getting through (stuff if I can work out how any crap could get through anyway) but also to make the air-flow swirl....I've also cleaned my Meter with carby cleaner,,,,worked a dream.... INASNT,,,I'm with you,,,,After my better 1/2 has ***** footed the car for a day,,,resetting it and then driving it seems to make no difference.....Maybe it does,,,, but such a small increase in power is not really noticable. Neil. Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90232 Share on other sites More sharing options...
_turtle_ Posted November 12, 2002 Share Posted November 12, 2002 took apart the airbox and afm today, only to find that i couldn't find the bloody carby cleaner in the garage!!! gotta go buy a can from super cheaps. wacked a pod filter back on instead of the air box. its a cheapo one, i fink theres a huge difference between brand ones and the cheap ones. my k&n use to give a huge induction noise. can't hear crap from this cheapy one. between the big names, there not much difference in performance, compared to the no names there is. sorry, its a bit off topic. Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90343 Share on other sites More sharing options...
Guest INASNT Posted November 12, 2002 Share Posted November 12, 2002 Originally posted by MegaGTS4 INASNT, I could explain it to you but its better explained in these two links! http://www.overflow.250x.com/tips.htm#reset (Dyno graph after ECU reset) http://www.skylinesdownunder.co.nz/tech/ecu_reset.html MEGA it might make sum difference on a r32 comp as it can be remapped,but it on a r33 i doubt it does anything! When i get my fmic on and s-afc retuned i am gonna reset the comp and see for myself if it does anything at all on the dyno. And whats with that dyno graph in the first link? its all over the show! Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90405 Share on other sites More sharing options...
_turtle_ Posted November 12, 2002 Share Posted November 12, 2002 how do u guys take the mesh part of the afm off? just rip it out? also, i reset the ecu lastnite, went for a long cruise. i don't think it does anything either. or perhaps my car is running ok so i don't notice any difference. Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90411 Share on other sites More sharing options...
Guest INASNT Posted November 12, 2002 Share Posted November 12, 2002 Originally posted by _turtle_ how do u guys take the mesh part of the afm off? just rip it out? also, i reset the ecu lastnite, went for a long cruise. i don't think it does anything either. or perhaps my car is running ok so i don't notice any difference. flat head screw driver and rip it off! as i said reseting dont do anything on r33 comps. they r eprom chips, they have set maps that alter slightly if knock is detected etc. Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90426 Share on other sites More sharing options...
akeenan Posted November 13, 2002 Share Posted November 13, 2002 ok i cleaned my AFM and everything was running nicely no stall etc and yesterday it stalled on me twice so im back to square one... Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90494 Share on other sites More sharing options...
Maddness Posted November 13, 2002 Share Posted November 13, 2002 what product are you guys using to clean your afm? im not sure what "carby clean" is ? thanks Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90642 Share on other sites More sharing options...
Neil Posted November 13, 2002 Share Posted November 13, 2002 I had a word about cleaning A/F meters today with the smarter BMW Techs at work,,,Carby cleaners are OUT,,,,Brake Cleaner is IN....aparently Brake cleaner leaves no residue. Neil. Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90702 Share on other sites More sharing options...
2rismo Posted November 13, 2002 Share Posted November 13, 2002 Brake Cleaner??? Was ist das??? Tah. Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90941 Share on other sites More sharing options...
akeenan Posted November 13, 2002 Share Posted November 13, 2002 i think he means brake fluid Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90966 Share on other sites More sharing options...
_turtle_ Posted November 13, 2002 Share Posted November 13, 2002 brake fluid?? i dunno about putting brake fluid through ur afm. i don't think thats a good idea. Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-90990 Share on other sites More sharing options...
teka Posted November 14, 2002 Share Posted November 14, 2002 No he means brake cleaner some of the guys at Audi told me about that, you can clean heaps of stuff with it (throttle bodies etc. even grease off clothes! as it leaves no residue ) It's almost like a dry cleaning agent. Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-91014 Share on other sites More sharing options...
Guest INASNT Posted November 14, 2002 Share Posted November 14, 2002 Originally posted by akeenan i think he means brake fluid LOL! brake fluid is the most corrosive stuff around! have u seen what a bit of it on your paint work will do? Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-91029 Share on other sites More sharing options...
_turtle_ Posted November 14, 2002 Share Posted November 14, 2002 anyone game enough to give it a shot with brake cleaner? hehe, i'm a lil scared of what mite happen, so i don't want to be the guinea pig. Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-91032 Share on other sites More sharing options...
akeenan Posted November 14, 2002 Share Posted November 14, 2002 LOL! brake fluid is the most corrosive stuff around! its a paint stripper... maybe i didnt give it heaps of thought before posting that reply it might work!!! Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-91187 Share on other sites More sharing options...
Guest INASNT Posted November 14, 2002 Share Posted November 14, 2002 Originally posted by akeenan its a paint stripper... maybe i didnt give it heaps of thought before posting that reply it might work!!! well lets just say that if u use brake fluid to clean your AFM u might as well drink sum while u r at it, so then your car could be at the mechanics getting fixed while u r in hospital recovering from poisioning!:lol: Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-91194 Share on other sites More sharing options...
akeenan Posted November 14, 2002 Share Posted November 14, 2002 lets all forget about this thread and move on eh!! Link to comment https://www.sau.com.au/forums/topic/5534-clean-your-airflow-meter/page/2/#findComment-91195 Share on other sites More sharing options...
