Geezzz guys the cleaner you want is electrical CO cleaner or Isopropyl alchohol. Go the dicksmith an buy a can.
Don't use carby cleaner --- it may deteriorate the plastic if left on.
Don't use brake fluid ---- it WILL deteriorate the plastic.
  • Replies 110
Guy's try the Brake Cleaner,,,It works a treat,,,,my car purrs like a kitten and I have cleaned the A/F meter at least 4 time. I also use it on my Slot Car Motors which rev to 300.000 RPM.
Neil.
Guest Brendanc
well I just pulled out the AFM and gave it a nice clean as some of you recommend.... WOW fantastic result, no more erractic idle problems, no more stalling. Everything running so smooth. I must denfinently add this to the TO DO list at service time!! :uh-huh:
I command everyone to do this !!!
I just did mine with Nulon brake cleaner.
Quick light spray, all the crap just came straight off. Put it all back together.
I could tell as soon as it started that it was better. It dropped down to normal idle speed faster and HEAPS smoother.
It just purrs now.
It makes sence, if the sensor has oil crap all over it, it won't give a true reading, or it might take longer for it give the right reading.
This will now be part of a standard service when I do the air filter/plugs/oil etc...
J
im gonna try out the brake cleaner tomorrow, after i go supercheapauto and buy some. do u just spray it a few times, then let it dry and put it back?
i saw some brake cleaner at k-mart the other day, on the back it said that it could be used to clean all sorts of stuff.
Yepp, make sure you read the label cause the first (cheap) one that I picked up said that it advised not to use it on plastic !!!!
Then i had a look at the Nulon one and it actually said that it can be used on plastic and rubber to remove oil and slime :P so I got that one.
Give the whole inside a good squirt, but be gentle when spraying the actual sensor in the middle. Sort of 1/4 press the nozzle and let is drizzle out onto it if you know what I mean. I'm not sure how robust the sensor is.
J
I went to Repco to get some stuff to clean my AFM.
I ended up doing as rev210 said and bought some electrical contact cleaner as it leaves no residue.
The guy at Repco said do not with a captial never use brake cleaner as it leaves a residue and can stuff up the AFM.
But I guess on the other hand guys here have used the brake cleaner and it's been ok.
Haven't tried it on mine yet though ... I'll do it Saturday and see if mine idles smoother :P
thats what the one i saw in Kmart said on the label, not to use on plastic. i think i'll go with the nulon since u've already tried it out and its all good. thanks. i'll try this out saturday morning first thing.
  • 3 weeks later...
I'm having problems with my idle too. You used an electrical contact cleaner? How were the results?
My Pod is a simota non oil based type so I'm wondering if it's got any cause to why my idle is so rough. Seems to get even worse when the car's been running hot or on a hot day. Some have said it could be a split vacuum hose too. HELP!
  • 2 months later...
Guest Pickled Icecream
I would strongly advise the use of Electrical Contact Cleaner.
After all, your AFM is an electrical device comprised of electrical
components.
I dont know about you, but my AFM neither squirts fuel nor
creates brake dust.
I have used Electrical Contact Cleaner on my AFM with great
success.
Accept no substitutes.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
