There are no "Specs" available for a Cefiro, closet would have to be S13 Silvia. I know they are listed on most machines as I just had mine done.
Like too_much_boost said, post up your itemised bill if you have one, $700 sounds reasonable though.
  • Replies 199
wtf specs for a wheel alignment? very strange? unless you specify something they will generally even up the camber if possible, set toe to neutral or in a little if you are running a lot of camber to reduce tyre wear.
Final bill was actually $635 - they must have seen me and felt sorry for me and charged me less :) I think that's quite reasonable.
They did a great looking job which I'm very pleased with - only thing is I have an unidentified white powder on the catch can (too much partying from the engine bay?) and a helluva lotta spray dirt/mud inside the engine bay (between the engine and fan belt kinda area) which I don't remember having when I brought the car in.
Probably just dirt from the car sitting around while they were water hosing their garage - I hope :)
I'm disappointed with the "no specs" thing, whatever that is, it's not exactly a stock car but they said it's not in the computer? I told em use the specs for the silvia cos it should be the same they said no prob come back next week for $80 << that seems like a bloody good price if they're doing toe/camber/caster/the works which pedders wanted (i think) $120 for. So I think I'll go back next week with my settings. I'd really love to have all my settings written down so I can just say this is what I want for sure - anyone care to suggest some numbers for toe/camber/caster etc?
Apperantly they said I should also get me one of these things as with the rear camber kit installed my rear wheels sits 'out' a little bit-
The rear feels ... different with the pineapples and camber kit installed (mostly probably down to the pineapples). The new plugs seem to make it run nicer too - MUCH nicer. I like it so far but won't be able to see it in action till it's registered.
While I was there a guy with a GTR was getting a twin zorst system installed and I noticed he had a nice kakimoto muffler... I told them I'd like to purchase from him to fit on my car - which should make a little less loud without making it crap on open throttle. fingers crossed on that one :cheers:
Next installment: Engineering certificate ;)
Hey, If it's a older cefiro w/ a zenki harness you might want to check the ground to the back of the alternator. Another thing is there is a fuse in the engine bay, marked "main" you might want to check that. When the ground broke off on the back of mine, it blew just about all of my fuses, and melted a few relays. Did a check light (looks like high beams backwards) come on right before it caught fire?
Got my wheels aligned yesterday and got a before and after sheet of the settings. Thought it'd be good for a laugh-
Before
Camber L -4.11 R -3.07
Caster L 6.34 R 6.50
Toe L 7 R 7
Rear Camber L -4.04 R -3.22
Rear Toe L 6.0 R 6.0
After
Camber L -1.32 R -1.26
Caster L 7.33 R 6.52
Toe L -.05 R -.05
Rear Camber L -0.57 R -1.00
Rear Toe L 1.1 R 1.1
Question - after they've set it up why did they set up each side slightly different?
Car feels very different now. Better overall at mid speeds but in slowish (2nd gear) tight corners the car kinda bumps through the corner, keeping the grip like crazy but bumping through it... I'm not sure if performance wise it's the quickest way through the corner but it feels tough :)
I will have to "test" properly at a track - which I can only get to when the car is registered. Still. Feels alot nicer now.
Yeah it is mechanical and yeah it's very tight so tight corners it skips HEAPS... whole car lunges up almost.. It just wasn't noticable before the alignment as much because the car felt like it sat more on the front wheels (with 4 degrees neg camber it makes sense).
Now when I go round the same corner it's not like the rear "slinks" after the front as much, it's more like the front falls into line where I want it to go and the rear half slinks and half bumps into place.
Might be the combination of wheel alignment and pineapples :)
My only thing is the garage said it's a 'sealed diff' and they can't change the oil :
When I get it engineered and rego'ed I'll be able to "test" more.
Well with rego out the next step in engineering will be getting documents from meggala for proof of purchase which he is sending tommorow woot!!
Armed with that I should be able to get through engineering next week and hopefully without any major hurdles there :
Finally someone said what I was thinking. *sigh* why oh why can't I ever seem to find a decent garage!?
It would be extremely unusual to have a diff whose oil can't be changed :) However, the easiest way to check is to stick your head under the car and look for a drain plug on the (rear, I assume) diff. If its in the standards R200 enclosure as per a lot of Nissans, it should be dead obvious.
LW.
  • 4 weeks later...
Was taking my car for a run yesterday (to keep it running nicely) and when I pulled it out of 3rd to put into 4th.. well.. something felt very very bad.
I had a hard time pulling it out and now 4th feels very squishy, and while it stays in there and seems to be putting power to the ground but it feels very very wrong (squishy/soft/no defined clicking in). I can push it out from 4th with no clutch at any rev quite easily too.
lol
Funny thing is silver my car is running better than ever.
It's the most reliable it's ever been, the cleanest and the best setup.
All I need now is engineering, blue slip, pink slip and I'm laughin.. my 4th gear is behavin now. So after that I'll try to reco the gearbox and that's it.
It's just that to get this far it's cost me too much and I've run out of cash for engineering+rego lol
weel good luck with it, lets hope soon we'll get to see it doing what it was built for
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
