This topic must have been argue countless of times. The response anyone get will depend on the site he is in.If in silvia wa ..they will say 180 rocks! but then in here skyline rulz.
Seriously if anyone here although owning a skyline can be on a fair basis and judge the two car fairly?
pros and cons?
resale?popularity?
maintainence?
Hope will recieve response on the fairest basis!!!!!!!!!!!!!!!!!!!
cheers!
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/
I guess it depends on what you're after. If you compare an SR20DET 5spd 180 to an RB25DET 5spd R33, then the 180 will have the price advantage and the practicality of a hatchback. But I'd think that the Skyline would be better in every other department, faster, better suspension setup, better brakes. Probably similar value for money so i guess it depends on how far you can stretch the budget and what your needs are.
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083223
IMO the Skyline is a far better all-rounder, but has a weight disadvantage if track work is your thing. As much as R32 guys like to go on about how light their cars are (or how heavy R33s are) afaik there's around 50kg between. Skylines definitely make more power stock, and (I think) a stock R33t will beat a stock SR20DET'd 180SX, but how many stockers do you see? Light mods, the SR powered 180 will win, particularly in corners. Medium to heavy mods, the Skyline will show the SR a clean pair of heels, although the extra weight will still haunt them a little in corners. Reading that back it sounds like the Skyline is a barge that doesn't turn... we're talking degrees here. Both cars handle absolutely brilliantly, and the Skyline wouldn't be far behind the 180SX, nevertheless the 180SX would be in front. Well the ones I've driven would be, anyway. I'm only going on the half a dozen or so of each that I've driven, so I'm not exactly drawing on massive experience here. I'm trying to be objective though ;)
180SX
Pros
Cheap
Parts are easy to source
Popular
Maintenance is fine, everyone knows them now
Resale - not really sure as I'm not buying or selling atm, but they're already cheap
Relatively light, good motors
Well balanced chassis
Turbo models had strong drivelines, good brakes
Look good
Heaps of hot up bits available
Easy to get going very well on light mods
Cons
Cheap
Popular = every prick has one
Some parts are still exxy
Getting long in the tooth, most have been flogged
Ultimately won't keep up with heavily modded Skylines
CA18 is relatively peaky
Skyline
Pros
Getting cheaper. Some R32s are nearing 180SX/Silvia territory
Popular
Still relatively light, good motors
Look good
Better quality interior than 180SX
Non GTR's also had optional 4WD (albeit only in non-turbo form in R33, unsure about R34)
If luggage space is your thing, get a Stagea (Skyline wagon)
Cons
Popular = every prick has one. At least there are a few different model types
R32s and S1 R33s getting long in the tooth, many (though not all) earlier models have been flogged
Stuff all boot space in R33
RB20 in R32 has bugger all torque off boost
If you're not familiar with them, spec differences can be confusing
That's all I can be arsed typing at this time of night :)
If you're thinking of buying, neither will disappoint!
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083368
Great response Marc!
I have owned both a skyline and a 180sx - and I have found the skyline alot more comfortable and nicer to drive. I had a 1993 180sx, so it had those crappy hessian bag type seats and trim. But if you get post 1994, I think the 180sx comes with velour seats and trim, like the skylines have. The 180sx is also quite simple inside, as you've probably seen, compared to the skyline.... But these are all asthetic qualities!!!
Like Marc said - the 180sx is alot cheaper to maintain. I have found the skyline to be quite expensive after owning a 180sx. S13's have an abundance of parts at wreckers and stuff and they are cheaper on fuel (but this is relative to what mods you do :) ). But this doens't matter if your not concerned about maintence costs!!
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083589
I currently own a CA18DET 180sx with just light mods (Turbo back exhuast, pod filter, boost up, etc) and my friends R33 with same sort of mods plus FMIC has about a three car lead on the 180sx over the quarter mile. :)
In terms of comfort and interior my old R33 wins hands down.
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083641
Agree - it's been said far many many moons, that the best mod you can do to your car is to 'upgrade' the driver.
But yeah, just test drive until you make a decision. When I was in the market, I ended up being torn between an S14a 200SX, the R33 I have now, and a TT Soarer. Three very different cars, and in the end the Skyline won it for me because it's more focussed than the Soarer, and more comfortable and smoother than the 200SX, and I planned to do a LOT of kays.
Edit: my god I'm a post whore when I'm stuck at home (flu). Sorry ;)
https://www.sau.com.au/forums/topic/55594-r33-vs-180sx/#findComment-1083979
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
