  • Replies 47
  • 3 weeks later...
autosalon GTR
gtst with r34 wheels
someone's te37s i think
marks gtst series 2 R33
autosalon - r32 gtr
tokyo motor show (i think) - top secret R34 gtr
nissan stagea with r34 GTR front end conversion
swoop r34 gtr
evlr34
rh9 gtr - i think belongs to exvitermini
r33 gtr with r34 front end conversion
andrews r34 gtr
IMGP0111.jpghks special edition r32 GTR - limited 10 run of this car only
it was a stock r32 gtr with a stack of hks parts installed and tuned as a demo car to show off the hks range of parts, called the HKS Zero R
jamezilla's r33 gtr
adamax's r34 gtt
winfield racing r32 gtr that won bathurst at autosalon
andrews gtr
r34 gtr in a factory chemilian colour
r32 ute / truck, gtst with rear end cut off for drifting
hks zero R special edition
Nismo GT4's, still made by Rays (under commission from Nismo however) :drool:
About the HKS Zero R's;
There were 10 HKS Zero R's made in 1994, only 2 were bought however..The remaining 8 we're parked behind the HKS factory for the last 10 years, gathering moss and rust..sad story :)
They were utter beasts too! RB26 stroked to 2.8ltr's, running a large single turbo with all of HKS's top of the line parts (ECU, EBC, HKS gauges, list goes on..) and were producing 400ps stock (around 300kw@fly) but could support 700ps (520kw@fly)..Racing-style fuel tank sitting behind the front seats (ie. no rear passengers) with the fuel filler welded into place behind the driver's side door..Will get more when I find that issue of HPI (and my only issue at that..)
cut it out you.
why would you put a r34 nose on a r33?  had me fooled.....
those zero r32 were in a old hpi.  i think.  what the story with them? im curious.  anyone know?
yea it was hpi or zoom i forget. it was at the back of some high performance garage and left there for years. what a waste
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
