Reminds me of when I stayed in a Holiday Inn in Japan a couple of years ago. They had a little info card with the rules that included "no smorging in bed" and proudly proclaimed there were "ice breaking machines" on every level.
Still makes me chuckle :D
LW.
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1084980
"It changes into indoor shoes and their clothes are changed in a locker room"
LoL sounds like..
"it puts the lotion on its skin" :rolleyes:
hahaha that was EXACTLY what i thought when i saw that one.
I like the use/invention of the word "unreasonableness"
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1085546
I bet they used babelfish, really it SHOULD make sense :rolleyes:
LoL I bet they did... :spcow: - word for word direct translation just doesnt work..
"Let's use it with a pleasant feeling for one another. "
I wonder what this is referring to....LOL
They probably dont expect many foreigners would use the gym..
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1085755
Yeah, "be respectful of others" is my bet (or literally "don't hurt their feelings", "try not to upset others", etc etc)
I wonder if you put those translations in systran/babelfish etc, whether they'd spit out 100% grammatically correct Japanese? :spank:
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1086230
this brings me to an awesome systran game we play at work when it gets boring...
type something in english, translate to japanese, then translate back to english... you get some really funny shit.
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1086259
oh yeah... systran = babelfish... babelfish runs on systran, er anyways...
Be respectful of others = Do to display the appreciation of other things be
Do not hurt their feelings = Feeling does not have to be damaged
Try not to upset others = The attempt which does not reverse other things
Rezz is a super person, with good skill in cooking potatoes = Rezz is the extreme person of the technology whose cooking the potato is good
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1086266
Heres some more from babel...
I got god like skills and is good with eggs = Depending upon me God the way to become technology, the egg good.
Let's use it with a pleasant feeling for one another. = Use that of the feeling whose feeling because of each other is good is permitted.
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1086596
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
