Reminds me of when I stayed in a Holiday Inn in Japan a couple of years ago. They had a little info card with the rules that included "no smorging in bed" and proudly proclaimed there were "ice breaking machines" on every level.
Still makes me chuckle :D
LW.
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1084980
"It changes into indoor shoes and their clothes are changed in a locker room"
LoL sounds like..
"it puts the lotion on its skin" :rolleyes:
hahaha that was EXACTLY what i thought when i saw that one.
I like the use/invention of the word "unreasonableness"
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1085546
I bet they used babelfish, really it SHOULD make sense :rolleyes:
LoL I bet they did... :spcow: - word for word direct translation just doesnt work..
"Let's use it with a pleasant feeling for one another. "
I wonder what this is referring to....LOL
They probably dont expect many foreigners would use the gym..
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1085755
Yeah, "be respectful of others" is my bet (or literally "don't hurt their feelings", "try not to upset others", etc etc)
I wonder if you put those translations in systran/babelfish etc, whether they'd spit out 100% grammatically correct Japanese? :spank:
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1086230
this brings me to an awesome systran game we play at work when it gets boring...
type something in english, translate to japanese, then translate back to english... you get some really funny shit.
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1086259
oh yeah... systran = babelfish... babelfish runs on systran, er anyways...
Be respectful of others = Do to display the appreciation of other things be
Do not hurt their feelings = Feeling does not have to be damaged
Try not to upset others = The attempt which does not reverse other things
Rezz is a super person, with good skill in cooking potatoes = Rezz is the extreme person of the technology whose cooking the potato is good
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1086266
Heres some more from babel...
I got god like skills and is good with eggs = Depending upon me God the way to become technology, the egg good.
Let's use it with a pleasant feeling for one another. = Use that of the feeling whose feeling because of each other is good is permitted.
https://www.sau.com.au/forums/topic/55726-gym-rules/#findComment-1086596
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
