Strut your Gaijin-tainted skyline fanatism in style!
A group of us are coming up in 2005 for TAS, and can bring with us T-Shirts for you guys...
they're basically the skylinesaustralia one that we got made for the Melbourne Auto Salon. Dark blue with white writing.
So if you guys wanna post up some sizes, I'll get some made up for you guys and you can pay me back when I meet up with you guys or something.
Front...
Thanks to our unsuspecting models, Evil, inark, noof, and Horus (from left to right)
Back...
https://www.sau.com.au/forums/topic/55808-sau-tshirts-for-the-japs/
think it was 20 bucks on last count, will have to confirm. we're gonna be doin a run for the NSWers as well so might as well do you guys while were at it
lol gee thanks rezz... i can feel the luv :grouphug:
I just got PM'd by Blitz, he's comin up for sure, i'm still unconfirme, so I'll give em to him to take up to you guys. So to get the order happening I need some sizes.
I'd get one but is there any way you can remove the "Melbourne" logo? You Melbourne wierdos always dump on Perth so I'd rather not be seen sporting anything with Smellbourne on it. Seen? :cheers:
*edit: theres no Melbourne logo is there... oh sh!t...
no but you just reminded me, it has an autosalon logo on it (under the URL in red and white), which I'll remove if you guys don't want it there.
i actually luv perthies, they've got good lookin women and awesome clubs, and really nice houses/mansions by the beach. so meh.
Dunno what it is, but Perth seems to have a higher ratio of hot women... although I live in regional queensland, where they marry at 19 and are fat baby factories at 22.
*chokes back a sob*
wouldn't mind one of those shirt but without the autosalon logo.
sciby maybe its time for u to move down to sunny coast :)
Hmmmm... normally that would be very tempting, but since I'm not going to japan in 2005, I've gotten a senior member position at the res college at the uni I work for... live-in network admin by night, better room, ensuite, better parking space, key to the member's bar...
*glee* :headspin:
While there'll still be Rocky 'women' around here, there'll be many, many imports from overseas... last year, there were 20 scandinavian women... :wassup:
f**k man that don't look like you...
BTW what happen to you last night?
Eh? Who does it look like? I get lots of Japanese girls saying "Brad Pitt/Leonardo DiCaprio/Kevin Bacon/Tom Cruise mixed-o togezzah"...
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
