R33 Skyline
Hypergear turbo
bosh fuel pump
e85
plazmaman plenum
plazmaman intercooler
hks bov
i.d 1000cc injectors
power fc ecu
full zorst sytem
spitfire coil packs
Stock motor
358 Rwkw on 20 psi
Edited by Abe2
R32 RB25DET series 2
Stock engine with 740cc nismo injectors.
Z32 AFM in coole piping, return flow front mount cooler.
Kando dynamics TD06 20G SL2 on ebay highmount manifold turbo smart 35mm gate (too small need 44mm).
BSA Customs 3inch straight through exhaust with hooker muffler.
Tuned on caltex Eflex E70.
Had a missfire and will need splitfire coilpacks and more boost once i have a bigger gate.
Boost was 11psi creeping to 15psi
R33 RB25DET series 2
550cc Deatschwerks injectors.
Bosch 984 Fuel Pump
Z32 AFM
Plazmaman FMIC
GT3076 ATP 0.82 Twinscroll
HKS Cast Manifold Extrude Honed, 50mm HKS Ext Gate
3inch straight through exhaust mid + rear oval mufflers
Venom 100cell Cat
Tuned on Shell V-power 98ron
Boost 22.5psi 4100rpm dropping to 19.5psi 6400rpm
Profec B II
PowerFC
224.6kw, splitfire coil packs, 3.5inch cat back(bashed out cat) plazmaman cooler an intake plenium, srceamer dump pipe, standard turbo 12psi, electronic boost an power fc..looking for turbo upgrade an advice appreciated, wanting 280kw comfortable...
01 ER34
RB25DET NEO
Z32 MAF
BLITZ 525CC I/J
BLITZ I/C
AEROMOTIVE 340 PUMP
HKS GT2535 1.2 BAR
POWER FC
Made 354PS to the wheels, Clutch started to fail anything about 1.2.
Replacing it with a Super Coppermix Twin and trying for a bit more torque and power.
98 R34 GTT
91k KM'S
Z32 AFM
HYBRID FMIC
600CC DEATCHWORKS INJECTORS
HYPERGEAR SS1PU TURBO RUNNING 16 PSI (MAXING AT 17 BUT FADING TO 15) WASTEGATE CONTROLLED
FULL 3" EXHAUST
BOSH 044 IN TANK
STOCK INTERNALS
BP ULTIMATE 98 RON FUEL
340HP - SAFE TUNE
Tuned by RPM Dyno & Performance Morayfield (Peter Roma)
I will put the sheet up on Monday when I go in to work.
Edited by RandomHero83
R33 series 2
splitfires
3" exhaust
3076 52t .63 rear
Tial 44mm gate
adapter to use on stock manifold
nismo 740s
044 in tank
Z32 afn
Z32 ecu and nistune
Tomei poncams
United E85
13.3psi
little bit of wheel spin coming on boost
98 R34 GTT
91k KM'S
Z32 AFM
HYBRID FMIC
FULL 3" EXHAUST
BOSH 044 IN TANK
STOCK INTERNALS
340HP - SAFE TUNE
Tune completed. Results:
R33 S2 coupe factory manual.
Stock engine
Steve Murch Hybrid Turbo
FMIC
Splitfires with NGK Vgroove racing plugs
Apexi pod with CAI
Exedy clutch
HKS T/Timer
Link G4 wtih boost control
Nismo fuel pump, oil filter, thermostat
Tomei dump/front with 3.5 inch exh
Power: 272kw @ 1.2 bar. Backed off due to major boost creep. Detuned to 255kw @ 1 bar.
Will get it retuned with turbo w/g port drilled out and aim for 280kw.
R33 GTS-T S1
(Before build)
Stock motor
Fmic
3.5inch exhaust, HKS super dragger from cat to rear
Nismo 555cc injectors
walbro 255 intank pump
HKS GTRS
stock manifold
z32 afm
Apexi pod in air box
CAI ducting
NGK coppers gapped to 8mm
Power FC + Hand controller
Turbosmart dual port BOV half plumbed back
Oil catch can
Oil cooler.
262.4rwkw @ 20psi , boost control issue spiking to 21psi. PULP 98.
Will scan dyno sheet and edit when i can find the damn thing :)
Lasted almost 2 years at this power level, however.. It recently spun a bearing, soon to come RB28 spool stroker kit and gtx3076r .. currently getting built.
garrett gt3076r low mount turbo
850cc sard injector's
sard rising rate fuel reg
ems 6860 ecu (rigolli tune)
arias forged pistons
walbro fuel pump
hybrid front mount
3in turbo back exhaust
made 234rwkw's on dyno dynamics shoot out mode on 19psi
detuned for rb20 gearbox ( too rich even at 19psi)
93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
550cc injectors
600x300x75mm Front mounted cooler
Xforce 3inch turbo back exhaust
Manual boost controller
ATR43G3 Ceramic roller bearing prototype turbo internally gated
4inch intake pipe
Nistune
Z32 AFM in cooler piping
Pump 98 fuel. Car maxed 302rwkws on 19.6psi
Video:
r32
un opened rb25 s2
greeddy / proboost plenum / factory rb25 tb
power fc/ z32 afm
nismo 555 side feeds
044 pump
gt3582r .82
factory exhaust manifold with 38mm turbonetics waistgate welded on.
good tune
301rwkw on 16psi
Edited by Matthew Black
rb25de+t
standard internals
og trust td06 20g
standard injectors sard fpr
fmic
z32
walbro in tank pump=rubbish pump
hybrid performance staem pipe manifold
tial mvr 44m wastegate
245rwkw@15psi
on bp 98
response monster!!!!!!!!!!!!!!!!!
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
