Yes the slot car and full UAS team will be at this one. Zed is sorted with small rear brakes and drag semi slicks and they fit up etc. Wheel alignment today and a tune tonight after some more incentives. I figure when I do a ten and get thrown out until I get a full cage may as well boot it over the line. 10.5 sounds the go.
Anyway anyone else up for it. Or come watch the boat break or enter the hall of fame.
https://www.sau.com.au/forums/topic/56025-wsid-wednesday-17th-nov/
drag semi slicks
What did ya get and what sizes?
BWAAAHAHAHAHAHAHAAAAAAAAA!!!!!!!!
Apart from the fact that it has the potential to do it and I can't really take the piss out of you, I love your wild claims John!! DON'T FORGET THE BURNOUT YOU SOFTIE !!!!!!
Oh, and don't forget your lippy :)
Adrian
BF Goodrich Comp TA Street Radials 275 50 15 bubble gum tyres with ballony side walls. Had to do a lot of mods with custom rear brakes and long studs etc to fit them. Set it up for easy transition back to circuit or drift though.
Got the line locker and yes did a test behind our dyno room and works well. Yes you have shown me the way with the burnout thing. Hard to get rid of the circuit raing hat and looking after the car syndrome.
Had to lose the little purse and lippy that Paul gave me and was hanging off the key ring of the Commodore. The wife and kids were really getting worried so a souveneer on the shelf now. Wonder what I get when I do a ten?
Im thinking I might say something nasty about the boat, tell everyone that Im coming and then pull a heartstring and not turn up. Dont send excuses send time slips!
I dont think I will come this week, I have had my 13 sec of fun and I might do one more once the Mods are done.
Found something interesting about my car zorst on Sat.
Std Dumps ->- I had a 3" Apexi front pipe - >-a 2.5" cat ->- 3.5" high flow race exhaust.
Those crazy japs
I have since replace the 2.5" cat with a 3" 7.5lt cat and a small piece of pipe to a 3" straight through muffler/resonator and left the back half of the 3.5" race exhaust. The car dropped about 5-8db and I picked up a little bit of mid range.
At least I can use the phone in the car now, and even hear myself think.
Got the lap top working Paul and tuned her up on 109 fuel 407.5 rwkw.T Was able to add a bit more timing but not a lot more power up around 7 rwkw. The main problem is the actuators are not strong enough and blow open and will only hold 23 psi. This may sound like a lot for some but the engine can handle much more, and the turbo's could flow a bit more if boost was able to increase.
The best bit is it makes 760nm at only 4400rpm and torque does not drop bad like some, 200rwkw around 3400 rpm and makes 24psi around 4300rpm.
The power does not drop off much high in the revs and keeps going to 7500rpm and will go more. It has such a huge rpm power ban even better than we expected. From 3400pm to make 200rwkw up to 7500rpm.
Great for circuit, drags or drift, won't mention what it would be like on the road. No need to do big launch at drags tomorrow night, just a few revs and floor it.
No exotic turbo's and manifolds with external gates, and only reground factory cams. Just flows smooth and has the right mix of bits.
For the love of god, I HAVE TO DRIVE THIS CAR!!
Adrian
I'm not going to be able to make it (again) due to work....... farkit !
I installed softer rear suspension and got rid of the HICAS, got wheel alingnment - so nearly there.
I just got to line up a tune and get the ability to get out there.
Really, I am trying - but shit happens.......
JP - I need to call you !
Remember it has a big fat Zed arse. Might put the big dual rear wing on hey?
Adrian you can be passenger no probs circuit racing but driving? I have seen you do burn outs remember, not driving my beast, can you imagine.
10.894 130.85mph 60foot 1.690 this was late in the night got the tryre pressure and suspension setting right almost out of fuel did a crap burn out Adrian you would have laughed, as got the line lock button on off all wrong, your fault for programming me with that one, did an OK 60 foot and still did a 10.8. the next run did a 1.597 60 foot but missed second gear change bad so pulled out of it. Then ran out fo night and fuel. More in it but now roll cage time before they let me back.
Did the BIG WWW.SKYLINESAUSTRALIA.COM sticker on the back proud.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
