  • Replies 1.2k
Will be out tomorrow :mad: then back home to do good 'ol speechs.. anyone want to do a OH & S speech for me?
heres a start
1. dont let little kids run around work with firecrackers
2. dont let kids stick metal paper clips into active power points
3. etc etc you get the drift :rofl:
also i wont be going tomorrow going to spiderbait WOOT :rofl:
BLACK BETTY BAM BALAM WOOOOOOOOOOOOOAAAAAAA BLACK BETTY :cheers:
skyGRTline:
oh, i see.......
meh, its all in the past. i bet you think im the bad guy dont you?! well just dont judge me on things which happened in the past.
Sorry, i wont be able to make it guys. am working the late shift at work and i wont finish until about 12am! ah, the life of a camera man/sound tech with ABC!!! :wassup:
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
