  • Replies 1.2k
I just realised that in that last pic you've managed to catch half of cassi's boob, which equates to a quarter of a full rack, not a bad effort, and now to find the other 3 quarters to complete the puzzle....*wanders off snooping around with a magnifying glass......
  • 3 weeks later...
IT'S TRIVIA - That's right TRIVIA Night at the Jerra Club every Tuesday night.
It Kicks at 7:30 and its FREE. Prizes come in Glasses, Bottles and Cartons
C'mon get social with your SAU Crew and sign on.
Show up about 7ish. Depending on numbers Teams can be organised on the night
Q. How many liners can fit in the Jerra Car Park?
Q. How many SAU members were bored last Tuesday night?
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
