It was gr8 to see all the lines there at the Jerra watering hole every Tuesday, Kates ford green 33, Andrews Wine red 33, Andrews black 32, Andrews purple 32, Shauns white 33, Jayces 32 or E's Bling Bling, NiKs white 32, Ewens Black 33, Leighs Black 33, my silver 32, and Mark the drunk :PBJ: . Then the 31's showed up and Boosted the numbers further and bought a few sheilas wiff em.
Yeah - Good Times :P
  • Replies 1.2k
Yeah - Good Times  :D
Second that! Good times,fer sure!
you ACT peep's really have it all worked out.......wish we were closer so we could spend some time at the tavern with you all. :D Have a drink for me 2nite Jayce.........Cheers Stace (& Pauly)
i had the same thing done about 5 years ago, they ended up have to remove the cartlidge it was flapping around and getting caught, causing me to fall over with massive pain at random times. All very funny.
i wont laugh because i know what its like :P i just hope it heals quickly :(
hope it does to, try pumping your self with glucosimaine that shit is great.
hmm good point actually... took some drugs they gave me last night i was tripping all of a sudden everything started moving head started spinning... that was my sign to go to bed... woke up this morning feeling ok but i wont be taking those drugs again :)
Well, its on again tonight people! I have to say it again... Lets get some interest back into Tuesday nights, even if you cant bring a Skyline (who cares) just come for a good time with your fellow enthusiasts!!!!
If no one shows up within 2 weeks then Im giving up!! Cos I used to really look forward to Tuesday night, but now you dont know if anyone at all will be there!
I know I only started going about 6 or 7 months ago but the times when we filled up 2 tables (as Jayce said) were so much fun!
There is no excuse! Even if you have indoor sport or a buggered knee, there are ways to get there!
Anyway.... I will continue to go because I consider myself a DIE HARD ACT SAUer (I hope that Jayce will back me up here :D) and I even went to the Central coast for this club so how hard is it to make it to Jerra pub for a few dinks and laughs!!! Hmmmm????!!!! :D
Rant over...
I had a arthroscopy for some damaged cartridge :D limping around at the moment should be back up and walking fine within a week or two and then a month or two of strengthening etc
I have to go see a specialist about getting one, have a damaged arterial ligament. It sux arse because randomly my knee will lock up and ill fall to the ground in pain... doh!
Anyways I would come tonight, but im stuck at work till 11PM... doh again!
Rant over...
you make it sound like you were forced to go. no one was holding a gun to your head. you chose to go, just like others choose to go to trivia.....
well plan at this stage is to be out next week for a little while providing my knee is feeling better and yes i do have an excuse because if any of you punks even accidently knocked it i would be down on the ground in tears like beau is when you call him a a tool :D
and yea nick mine was not that bad before i went in for surgery but i couldnt run or do anything to adventurous or yes i would be down and out for a while :D
Hmmm sounds like compression lock? try easing the clutch a little more when you're cornering instead of popping it straight out, you may lose a fraction of a second through your lap but you won't have the risk of sliding right off...... :P
Hmmm sounds like compression lock? try easing the clutch a little more when you're cornering instead of popping it straight out, you may lose a fraction of a second through your lap but you won't have the risk of sliding right off...... :rofl:
you nub
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
