  • 1 month later...
  • Replies 1.2k
  • 1 month later...
  • 2 months later...
  • 4 weeks later...
Just quickly,I remember last year at Melbourne Cup time,there was no trivia on(as everyone was too p**sed at the racecourse). However,E and I will still be making an appearance,even if it's only for a feed! Good SAU company is always welcome!
Well,E,me + Gus were there last Tuesday,but as the alcohol from The Melbourne Cup had taken over,there was many a bogan,and a heap of fistfights,so you all didn't miss anything...
We left early,too...
  • 2 months later...
Trivia's back on bitches!
Bullet32 and myself will be there tonight, there will most likely be others there too.
For those of you that are new, it's not really trivia as such.... it's more of an eat/drink & be merry type of arrangement. There just happens to be a trivia comp on in the background.
We'll see any takers out at Jerrabomberra pub around 7:30, don't be shy :laugh:
I thought you would have already known Jayce, I cant drive for a little while no bigie just stupidity. I wasnt even in the skyline. I am happy now to just pull the car to bits and do some things that need doing lol.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
