This is my 2 Litre N/A Skyline
My names Mick & i,m from the UK
So far i have put 17 Inch Split Rims On
Apexi Induction Kit
Full Custom Stainless Exhaust { 5 1/2 Inch Outlet
Carbon Front Splitters
Illuminated Nismo Plaque { Under Stereo }
On Dash Rev Counter
GTR Skirts going on very Soon & Being lowered 40mm
Heres a couple of Photos
https://www.sau.com.au/forums/topic/56343-my-2-litre-r33-na/
muhahaha... someone with a slower car than my GTS :(
j/k one of my mates has an RB20E 4Door. if you wanna be really cool, get the rocker cover from a VL RB30E and put it on there (it fits right on as they're both SOHC) and then completely BOGGLE everyone's minds when you show em your R33 has a HOLDEN badged engine in it. Works a charm on my mate's car :D
wow, thats amazing, how did you manage to lower the car and put the side skirts on without moving the car, and doing it within a split second!!! the car is in the EXACT position as a photo in your first post and all the shadows thrown from the car and the wheelie bin are identical, not to mention the dates on the photos are the same. do you have a time machine?
which 2 pics?
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
