OK, I'm lucky enough to live about 10 minutes drive from a small RWYB circuit in the mountains. While the circuit itself isn't anything special, it's still a popular place for locals to try their skills on a short, technical circuit, where power isn't everything. I've been going there most Saturday mornings for the last 4 years or so, so I figured it was about time I started sharing some of the photos :) Anyways, I'll try and keep this thread updated with pics (from time to time! :) )
So, here are this morning's pics - today was a pretty normal day. A couple of small clubs made an appearance, and it was nice to see an NSX on the track too...Most afternoons are dominated by bikes and in the summer there are some organized events aswell.
The track. Small, on a hillside. Zero run-off if you make a mistake. It's better suited to smaller, more agile cars. It's constantly being updated, renovated and improved. Recently they're installed a spectator's watch tower, must be 4 stories high, and it gives a good view of the action.
That's all for this week.
Dave
https://www.sau.com.au/forums/topic/56439-sports-land-yamanashi/
Justin - yep, you're free to walk around as you please. It is a small track, quite laid back in many respects.
The course is short, 1.2KM...shorter for the drift course.
Their webpage is here
In addition to the main track, they also have a dedicated R/C track, with meets and events.
They're open most days (though weekdays there is hardly anyone there, which can be good if you're lucky enough to get the track to yourself! :rofl:) and throughout the year...
Dave that looks the goods! Almost reminds me of the old Lakeside here in Queensland.. But smaller lol.. I'll be living in the yamanshi prefecture in about a weeks time.. Is it hard to get to that track? I take it they have dori meetings sometimes? Would you be keen to meet up?
Dave, thanks for the photos. I've heard of Yamanashi Sportsland...Short track is good though, keeps the max speed down and competitve times can be acheived for all cars and would be great for the MX-5 as you can see a few are there. If you have a high powered one car, well I'd expect you'd know how to control it.
Poida - the track is nestled in the mountains on the northern side of Yamanashi (towards Nagano). It's not that hard to find, once you're on the right road and I can provide directions if you're interested. You'll definitely need a car to get there though. It's hard to say if they'll be any decent action on any given weekend, it varies alot.
Unfortunately I've got to work this Sat/Sun...so I won't be able to meet up....I hate work! :P Where abouts are you going to be living?
Troy: by far one of the fastest (and most popular) car types I see on the track are Evo's (there were a couple running last Sat). Also PM'd you!
That all depends on the car. While it's a small circuit, perhaps not well suited to high powered cars, it also has a short straight, that is all uphill (and a steep one at that) so you need plenty of low down power to get up it quickly.
Most of the time people are lucky to get into third gear much before braking (which can be left right till the last minute) and taking the sharp left hander....
Briefly stopped by the track today...and discovered I'd missed out on some kinda event. There was a TV crew there, along with this:
Not sure what went of before I arrived, but there was plenty more drama to come once the bikes had gotten out of the way:
Next up was a mix of cars, including a nice hachiroku:
a couple of RX7's
a very quick Honda Beat:
and an absolute bad-a55 S14 Silvia:
And then there was the the Scooby....
10 minutes into his first session and then...SCREEEECH...BANG. Somehow he lost it on the corner....
busted radiator. The front end was totalled. Car wouldn't start. He'd also managed to spin it, wrecking the back end - you can see the rear wheel is pointing outwards. Owner didn't seem that bothered about it...Shame too - I had a look around it just before he went out. It was an absolutely minter and ran really well.
That's the trouble with SLY - the track is quite technical, and with zero run-off is totally unforgiving of mistakes. I've seen many, many an accident in the last few years and it's one of the main reasons I've not yet raced myself...
Anyways, to wrap up - they hold a Mira Cup during the summer, here are some of the "cars" lined up:
And a shot of their R/C track.
That's all folkes!
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
