im sure uve all seen it... does anyone have one in Australia yet?
Not with the running gear... ive seen one of the 240RS's already... the actual R34 GTR Front end? Does anyone in Australia have one yet?
I ask because my gf is in need of something new as the soarer doesnt suit her needs anymore... we looked at a stagea today at the dealerships... it was a 97 model.. lowish ks... pretty stock and only 18k.
Thats pretty cheap and i was thinking about importing the R34 GTR front end conversion for it if she does end up getting it to do something a little different. altho im sure knowing my gf she will change her mind again and get something like a Jazz.
incase u dont know what im talking about...
https://www.sau.com.au/forums/topic/56525-gtr-wagon/
I do believe skyline imports already has a masa kit, compliance plates for cars that already have a masa kit on it, and a mould of the masa kit. But yeah it's probably cheaper to get it put on in japan, as masa's not the only one that does that kit now.
I dunno about skyline import's moulds, last time they tried to do the kakimoto R33 kit, instead of adjusting the wheels with a castor kit so that they didn't rub against the tyre well, they modified the kit so the wheel arch was further back.
https://www.sau.com.au/forums/topic/56525-gtr-wagon/#findComment-1094875
They have the kit up to $10,000 fitted was the last quote I was given off them, they are not legal due to the fibrelass Guards and the cars they have converted would be shitty stagea's which needed a re-spray.
We are working on full repo guards out of steel.
https://www.sau.com.au/forums/topic/56525-gtr-wagon/#findComment-1094878
yeah i know of the MASA ones... like mmonkey said theres a few places in Japan doing it at them at the moment. Problem is i would have to get it shipped as my gf wants a car thats already here in the country so i wont be able to put it on in japan.
so what would u basically need?
-Guards
-Lights
-Bonnet
-Bonnet latch
-Bar
that would be about it wouldnt it?
the hardest thing to get would probably be the guards as u would have to manufacture up ones that fit on the stagea and that the lines flow through the whole car... you couldnt just cut the front of it to fit the lights could you?
https://www.sau.com.au/forums/topic/56525-gtr-wagon/#findComment-1094902
and bumper support, the rest of the brackets you should be able to fabricate using pieces of steel
Why don't you just get standard GTR guards (metal), and fit them to the stagea, if they're too long, shorten them, and then blend it with bog. If they're too short, add more with fibreglass. Surely that's gonna cost you waaaaay less than $10,000
https://www.sau.com.au/forums/topic/56525-gtr-wagon/#findComment-1094907
inark, there is another thread on the R-34-style front here ...
As per SK's discovery, the R-34 and C-34 guards aren't interchangeable, which rules out Shan (funkymonkey)'s suggestion. I think there was also a mention of a body crease that's on the R-34 that doesn't appear on the C-34, or vice-versa.
They do look hot though, don't they?
mcnamg's photo gallery is GOLD for Stagea pics, as I'm sure all of you will agree...
It's here. Nice work, Glenn! :(
Nick T
https://www.sau.com.au/forums/topic/56525-gtr-wagon/#findComment-1095890
the only thing that you use that isnt genuine or aftermarket r34 gear is the special stagea specific guards which at the moment are frp which is pretty crap if you ask me.
there are also other pics in my gallery showing some other stageas with different kits on them feel free to have a look through them.
thanks for the plug goldzilla ;)
https://www.sau.com.au/forums/topic/56525-gtr-wagon/#findComment-1096188
Inark,
I think Gary (QLD SAU GURU) has a 260rs, dont think anyone has compliance for them yet, but I hope it happens soon as I am buying one in 10 months - can wait.
Ken
Theres a genuine 260RS here in melb... it belongs to some guy that used to own a car yard... awesome looking thing... even with the rice :D will try and find the pics i took of it one night on the way home from work.
https://www.sau.com.au/forums/topic/56525-gtr-wagon/#findComment-1097143
they have to be one of the best lookinwagons ive ever seen (even tho they do bare a slight resemblance to the ever hated VOLVO lol)... especially with the huge front mount grinning at u haha.
https://www.sau.com.au/forums/topic/56525-gtr-wagon/#findComment-1098033
nothings not interchangeable... hell we put an R32 front on a 180sx :cheers: (well someone else did for us). All you need to do is make up adapter brackets and probably make extra mounting holes in the chassis (probably will weaken the structure) then you use bog or fibreglass depending on how much needs to be done, to blend the bits together.
Its been done since waaaaay back in the day :D
https://www.sau.com.au/forums/topic/56525-gtr-wagon/#findComment-1099060
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
