Hi Guys,
i got some gears (sump extension kit, 10row cooler & oil filter relocation kit, cam gears) going into my GTR32 and wondering is it possible to modify my existing oil pump for more flow? I am think either modifying or get a new N1 oil pump but would like to hear any past experiences which some of you guys might have.
thanks in advance.
glenn
https://www.sau.com.au/forums/topic/56569-gtr-oil-pump/
All I know is I've been told to get a new oil pump as the stock on the GTR R32 is far to small. Look's like I'm after a new N1 as well. So be intertested too on the advice.
BTW My beast was fairly well modded when I took delivery but some of the essentials have not been done to support the other mods. It has like a pair of GTR R34 N1 Turbs, all the HKS, TRUST and Apexi bling blings you could want for Christmas.
But no Oil Cooler, larger Oil Pump, Sump, Radiator. But hey - I no complain. Saved me heaps and has given me something to work towards.
I have Nismo Fuel Pump, SARD Injectors and Fuel Reg being installed and tuned today ;)
https://www.sau.com.au/forums/topic/56569-gtr-oil-pump/#findComment-1096234
the problem with the r32 pumps is the drive engagement is too small, nissan knew this and fixed it on the r33 an r34 you should invest in getting your crank collared then fit a newer pump.. You can mod the stock pump by changing the spring rate in the pressure valve, this is all the N1 pump is anyway, something i found out after paying for a r34 N1 pump then having a close inspection and realising the stock one is the same!!!
https://www.sau.com.au/forums/topic/56569-gtr-oil-pump/#findComment-1096270
....you should invest in getting your crank collared then fit a newer pump.. You can mod the stock pump by changing the spring rate in the pressure valve....
i have checked with Nissan and seems that i can get a new collar from them. Is this the same crank collar you are referring to?
thanks
glenn
https://www.sau.com.au/forums/topic/56569-gtr-oil-pump/#findComment-1096447
Talk to Ed about this, Greg from Pro Engines did the upgraded spring in the pressure valve on mine which is the only difference on a N1 pump. Its a piece of cake to do when you've got the sump off.
Ive also got Tomei sump baffles sitting at Ed's if youre interested ;)
https://www.sau.com.au/forums/topic/56569-gtr-oil-pump/#findComment-1099698
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
