Hey guys, I've done a few mods to my R33 now I've got the taste of power, I want more
I want about 250kw at the wheels, without all the lag
What size turbo have people found will do that job
Sex should be like a skyline- Quick obscene and loud enogh for the whole street to hear when you come
https://www.sau.com.au/forums/topic/56716-whats-a-good-street-turbo/
So u made 250rwkw @ 17psi with standard ECU, standard injectors, standard afm?
safc2 etc?
oh and my turbo choice would be HKS GT-RS
i didnt say that. The ECU is stock meaning in does have a chip in it but it is not an aftermarket one such as a wolf or a Powerfc. And yes i do have 550cc injectors
the xr6 turbo is pretty big its like a gt30 or 35 or somethin, highly doubtful it bolts straight on to a stock manifold...
sydneykid: so out of the GCG high flow and a HKS 2835s, would u still pick the high flow? im deciding which one to go for, but a few $$ extra (from nengun 2835 is 2500 delivered) would it be worth it?
ben...
ben...
I decided against the HKS as I wasn't going to pay more money for something I could achieve with a high flow of the standard turbo. Don't get me wrong the HKS GT2835 would be great and I bet would be maybe 5-10% (better then high flowing your standard R33 Turbo but for the money why bother, you could save yourself plenty by going the high flow way and at least you can put that into a better dump or manifold :)
just cos you save money on something does mean you can't spend it on something else the car may need :D
I am currently highflowing my stock turbo to a GT30 standard.. not sure what style like GT3030 or GT3040 but enough to give about 600 odd horsies :)
GCG Ball Bearing high flow, 265 rwkw and more power EVERYWHERE than standard:cheers:
Hi sk.
What about the power delivery of the hi-flow?Do you have any dyno graphs?
If no.How does it compare to a 2530/35 garett or hks.You had tomei poncams as well for that figure to right.
What are the comp housings/exh housing specs of the stock unit high hi flowed.
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
