Group Buy: D2 Racing Coilovers *CHEAP*
D2 Racing Coilovers
- 36 levels of damping force with adjustable function
- Plastic dust cover
- Sport spring: 3.5kg/mm to 18kg/mm could be chosen
- Ride height with adjustable at least 100mm
- Monotube design, 44mm shock piston, 50mm body
- Single cylinder design, action by Nitrogen and Hydraulic oil combine
- Aluminium bracket
- Qualified by World ARTC (Automotive Research Test Centre) standards
- Coilovers come with front and rear strut mounts
- 23-25KG per set
- 1 year full manufacturer warranty on manufacturer's defect/s against leaks.
- Includes all neccesary accesories in the set.
Spring Rates stated below:
- Skyline R33 13F11R
- Skyline R34 15F13R
All other models, please check the availability on www.d2racing.com.tw and email me your model so I can check with supplier. If the website does not have the model of your car, that means my supplier cant provide it.
D2 Camber Kit for adjustment of damping
With purchase of coilovers, AUD$130.
Without purchase of coilovers, AUD$200.
D2 Pillowball Mount (Suit McPherson Strut Cars) for adjustment of damping
With purchase of coilovers, AUD$110.
Without purchase of coilovers, AUD$160.
Pricing stated below
- All R33/34 Skylines - AUD$1,300
All other models, makes, please check the website www.d2racing.com.tw for availability. If they have the model, make of your car, my supplier can supply it. Prices vary for different models.
Order numbers
Minimum order of 30 numbers from manufacturer, but sample order only a minimum of 10 numbers are required. I have got 2 people including myself getting it, so I need at least 8 to buy.
Payment
AUD$1000. to cover the initial purchase cost and freight and insurance, the rest of the twenty percent goes to duties, tax, port clearance, broker fees, documentation fees etc. The rest payable when the goods reach Australian shores.
Coilovers - Closing deadline for orders 2nd of Jan, 2005
Arrival to my port - Early of Feb, 2004
You should get it by Mid of Feb, 2005
Shipping between interstate
Cost to Cost or provide your own courier. Weight is only 23-25kg per set.
Please kindly take note that this is only a ONE-OFF agreement with my supplier. Due to the fact that there is an official distributor of D2 products in Australia, my supplier can only honour this ONE-OFF purchase.
My supplier is US based, product is from D2 Taiwan.
For more information, please email me at [email protected] and I will consolidate all questions before making a call to my supplier in US for clarifications.
https://www.sau.com.au/forums/topic/56815-group-buy-d2-racing-coilovers-cheap/
yep, D2 has quite a few other brands (around 20) but all using the same tech and stuff. Because the brand D2 has quite a few official distributors, therefore other retailers are using their own brands on the D2 coilovers as OEM products.
yeah ... only R33/34 and Sils ...
But there's always a way, that is to send the original set of suspension units with dimensions of the undercarriage over to them to do a custom order out, but thats gonna cost too much.
Sorry, I've only got for R33 and R34. Chassis difference between the two.
As for the difference between the GTT/GTR and the GTS-T/GTR, will keep you update but according to the supplier, there's an adaptor for both variants of the R33, R34.
I have a set on my R32 and I can vouch for them.
The 32's are the same as the 33's just use a different pillow ball top on the fronts.
Look sweet as and are really top quality guys.
You won't be dissapointed hey.
Hey there, thanks for the vouch and the kind information for all to share around.
Cheers
Hey,
Im a new member here, just got my skyline...... its a stock gts-4 non turbol r33.... would these coil overs fit my car? having hicas and 4wd, does that make it similar to a gtr suspension set up or gts-t? Heaps interested though.
Based at camden also(south west sydney), if u were wondering.
Thanks,
Pete
Hey,
Thanks,
Pete
Hi Pete, the coilovers set comes with adaptors for your model. Besides, the chassis for the GT-R and the GTS-T are similar ... so shouldnt have any problem. The coilovers are based on specific models for specific cars so it's needless to worry about.
Hope this helps.
Cheers
Guest
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
