Hi
I have just been thinking that an Skyline cruise down the Great Ocean Road would be a good thing considering the excellent summer weather. Would be a good opportunity for the SAU people and others to shoot the breeze and enjoy a really fun drive.
The cruise could begin in Geelong, say at Corio, which gives everyone a good meeting point. The Melbourne people could meet up in the city if they like and then cruise to Geelong or everyone can just meet in Corio. I am from country Victoria and me and my brother would meet in Geelong (2 hour drive for us :)).
Starting from the meeting point at Corio, the cruise would head down the highway to Torquay with numerous stops along the GOR before finishing in Lorne.
From Lorne, we could all cruise back together or people could leave at their leisure. I was thinking that the cruise could take place in late December or early in the new year. Let me know what you guys think of my idea or if its already been done before.
Steven
https://www.sau.com.au/forums/topic/57142-great-ocean-road-cruise/
For all that it matters the speed limit at this time of year may as well be 40 as our last cruise the majority were stuck behind someone doing that and only a bayside blue r34 gtr was able to get past and have some fun! :(
Ah this is very true... Some other cruises I have been on were run early in the morning when recalcitrant holidaymakers are less of a problem. Also you can stop and have breakfast in Apollo Bay... Then return the less busy inland route.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
