Just wondering if anyone has information on tests done to determine the flow benifits of various 'hard pipe' upgrades. Cusco ,HKS and others have kits going so perhaps there
I have started to notice that the factory R32 gtr piping is less than perfect. As an example the metal pipe in the guard that connects to the rubber one with the plenum on the otherside. Just inside this metal pipe is the connecting pipe to the BOV's and it has a nice big lip of metal protruding into the airflow. Not to mention the cast metal pipe that joins the two turbo outlets with the "twin turbo" badge on it.
https://www.sau.com.au/forums/topic/57204-gtr-hard-pipe-upgrade-improvements/
One word.....plugs.
I had a dinner cancellation and I thought " I'll just nick off to the drags, my plugs are a bit sick but surely a few runs will clean them out....."
I ran 3 times and went home. Each time it got worse. The first run was a terrible 13.2 (spark giving out under load above 4500rpm) and the second and third were a joke. The Tomei cams rough idle mixtures pretty much killed the plugs in a few weeks of everyday around town driving.
I ripped the stupid irridium plugs out (the previous owner put them in) last night and put some old NGK coppers in, good as new (for now). The Power FC goes in on thursday and Lumpy is giving it a tune so the mixture issue will be resolved. I'll go down again when I can, knocking a second and a bit off that time will be very easy.
For the $$$ they fetch or the pain they cause to manufacture, I don't see them as a cost effective mod.
Big hp is being had with stock GTR piping, as imperfect as they look. That's another reason I wasn't quite interested in the aftermarket piping.
Would love to see some test results if anyone has done it though.
People have been mucking around with them for some time. Here's an example with a modification of the 'twin turbo' pipe that yeilds a very good result on track cars worth 20ps on a N1 equiped gtr apparently.
Guest two.06l
it might surprise you but the HKS kit uses the pipe with the "nice big lip of metal".
you know, rev210, a big single would fix that problem right up :)
It doesn't suprise me. What you mean is they don't replace that pipe right? I can't really understand why you would re-make what seems like a mistake in design.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
