My RSX wears 15x7 and 15x8 Volks , these are very light for their size and help bring the unsprung weight down . Not sure how 11" rims would go on the back , will make tyres expensive (good ones ) . One thing to watch with semi trailing arm IRS is the camber and toe changes through its travel . If you can reduce the body roll to a minimum it helps . What rim diameter and rubber profile were you looking at ie 265 50 16 ?
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1108018
Not 11", +11.
The specified sizes from RS-Watanabe for the DR30 are as follows (wheel type, size, offset):
F: F8 15-70+21
R: F8S 15-70+15
Based on that info, you should be right, or VERY close to right....
I'll be running 16x7.0" & 16x7.5" F8's on my DR30 when I can affor tyres....
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1108203
I've got 16*7.0" & 16*8.0" Enkei 7 spokes (dont know the model number and cant be bothered pulling a wheel off to check) +32 on it atm, and Watanabe RS8-2 in 15*6.5" +34 stored away. Just need some SSR Mesh and a set of Volks and then I've got a set of each type of cool rims now lol
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1109029
they will fit but will stick out from the guards more giving it a phat look, the less the offset is the further out from the centre they will sit..... my rs8s' wantanabes were the some offset as bensDR30 mentioned but 7" at tne front and 7.5" at the rear, the 17" P1's i've got now are 8" at the rear with an offset of 22, just fit no scraping....
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1109032
Always dramas putting big boots on strut cars with zero scrub geometry . Have you noticed that most late model cars have rims with deep hub sections and spokes that come out a long way before joining up at the outer part of the rim section . Z32's , some R32's and S14/15's had fairly unique wheels to cope with this style geometry and wider four piston brake calipers . There is some serious grip to be had with 205 tyres though , need the right tyres and suspension . I'm using custom wound 185 in/lb front springs and HDT V8 spec Bilsteins front with 195 in/lb rears and std spec Bilsteins plus std roll bars . My caster rods have nolathane front bushes and front strut spherical joint tops . Next mod will be adjustable caster rods and just about as much positive caster as I can get . Cars of the R30 era dont use much caster (compared to current cars) and what tends to happen in hard cornering is this . For a car set up with static negative camber the body rolls away from the inner radius but the camber remains negative meaning the contact patch of the tyre is reduced to the inner part of the tread . The extra positive caster changes the camber from negative to positive on the inside wheel and puts more of the tyre square to the ground . This gives more cornering grip better turn in and more selt straightening . The only disadvantage is higher steering effort but pwr steer handles it ok .
Cheers A .
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1109560
Anyone using 4piston calipers and have rims that fit? Its a nightmare of mine.I had to fit longer studs,fit spacers and then i can only use a 6.5" rim with a 205 tyre on the front to keep the tyre off the strut.sad me.
The rims on my car are silvia (shudders) offset, i had to use a 25mm bolt on spacer (way over kill) and it all fits with R32 calipers/R33 rotors...What brakes are you using?? Im currently running 215's at the front with no drama's at all and 235's on the back without a hint of rubbing...
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1109641
Im using S14 200sx brakes,23mm custom spacer and it just fits.I had my strut converted to adjustible hight/coilover with king springs and koni inserts.I have 3.5 degrees negative camber and boy does it turn in!
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1110372
Affordable longer studs are standard on the R31 GTS and not very expensive , for really long studsyou may need to look into Nizmo bits but very expensive . I wasn't looking but would not like to crash a car with wheel spacers and get caught , Insurance will wipe its hands and the relivant Traffic authority will throw the book at you . Definately not a legal mod and easy to spot if you know what to look for . The right wheels are out there and give handling advantages over incorrect offsets and excess negative camber . Up to you .
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1110643
Im using R32 calipers and R33 non turbo rotors due to the four stud pattern, but from what i hear now you can get the R33 turbo rotors in a 4 stud pattern from DBA..Prolly cost a bit but worth it because i can throw the spacer away! Im also running S13 coil overs alround (cheers to Crimmo for all this) :)
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1110786
Hmmm.... well the RE5040's on the front and RE55S on the back seems to be a good mix atm, weren't too bad in the wet/damp in the hills tonight, the 104km/h dinger is freiking annoying and the car definitely still has the speed limiter, though it seems to be off the clock when it hits it, was somewhere near 6000 in 4th? Not sure, wasn't really paying much attention to the dials
https://www.sau.com.au/forums/topic/57414-157-11-on-a-dr30/#findComment-1121617
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
