Nismo 20th Anniversary background pic...
Everyone askes about the air deflector...helps the wind to blow over the sirens and reduces distortion when using the PA.
Brrrrrrrr! WRONG. :(
I got OW3NED bigtime over at nissansilvia.com when some guy told me it was a bug deflector... I thought it was for wind, but he was right in saying it's there to keep bugs off the windscreen for persuit purposes. Please don't argue with me on this.
I talked to a retired police sargeant (one of our students) and he confirmed that it's a bug deflector, even showed me some police internet site explaining the exact positioning and angle of the "Bug Deflector" for various models of police cars Crown, RX-7, GTO, GT-R etc.
are you serious...not convinced that is the sole purpose, I will have to ask the cops next time.
Yes, I reckon we're right about the wind...the bug deflector is going to serve that purpose anyway...in keeping bugs off by channeling the air over the windscreen, cause I can't see it blocking much if you said it was head on.
エアロブーメランタイプの散光灯に、ボンネット上には高速隊特有の虫除け板を装備する。
バックミラーはシングルで、吸盤式のミラーを追加している。
And translated: Equipped with an Aero boomerang type siren, with an insect repellent board especially for high-speed persuits on the bonnet. The single rear-view mirror also has an added suction cup type mirror.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
