About to do some maintenance work on the car, thought I would post the part numbers in case anyone ever needs them (all Nissan part numbers):
*A/C Belt: 11920-30R10
*Power Steer Belt: 11950-59S02
*Fan Belt: 11920-42L01
*Bottom radiator hose: 21503-72L00
*Top radiator hose: 21501-05U00
*Fuel filter: 16400-53J10
*Oil filter: 15208-H8911AU
*Wiper blade (500mm): 28895-79903
*Wiper blade (475mm): 28895-89902
Hope that helps
https://www.sau.com.au/forums/topic/57514-r32-gtr-part-numbers-for-reference/
Australian built r31s
10 dash lights cluster.. P/shift etc. = 25020-j7003
4 dash lights ( right side of the dash) Oil,Fuel etc = 25025-j7001
Series 3 front bumper support = 62030-91S30
Thermostat - 21200-42L05
Ryco oil filter - Part number Z145A
Ryco air filter - Part number A360
Ryco fuel filter - Part number Z202
Import - GTS, GTSX etc
Import rear window defog dash switch = 25350- 51S06
RB20DET AFM - 22680-02U00
RB26DETT AFM - 22680-05U00
RB26DETT FUEL FILTER - AY505NS004
RB26DETT SPARK PLUGS - 2240158S16
RB26DETT OIL FILTER - 15208H8911
R33 GTST RB25DET
FUEL FILTER - 1640041B05
ROCKER GASKET COVER - 1327058S01
1327058S11
TURBO INLET GASKET - 144154P200
SPARK PLUGS - 224011P116
EXHAUST MANIFOLD GASKET - 1403621U00
EXHAUST STUD - 14064N4200
guys;
thanks for the info. just wondering if these are the numbers on the part or numbers off the Nissan software? i was recently at Lennock Nissan in Canb and queried the number on a package as it didn't match up with the number on the microfiche diagram printout they gave me. their response was 'oh don't worry about trying to match the numbers because they don't' go figure...
i thought i'd ask seeing that they are mercenary about parts ie ex Japan stuff can't be returned and they ask you to ID the part on the printout so the onus is on you to get it right...again, go figure.
thanks
Good stuff fellas!
Part numbers are great but if they were posted in a permanent section it would be better!
http://www.sau.com.au/forums/showthread.php?t=56447
What do you reckon? :P
  • 4 months later...
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
