did you put any water on electrical system?? like fuse or connectors...
fgive ew hours to dry out...
sounds lilke short circuit problem
i didn't cover anything when i sprayed the water. so this might be the problem..
also when i sprayed stuff on, the car was a little hot.. when i spray water on i can see smokes come out from the bottom, where the turbo sits.. so i think its something to do with the turbo.
Man thats just not smart.... no offence....
As mentioned above, check all your intercooler piping. How is it idleing? Is it popping when on idle?
i dont think spraying water around your exhaust when its hot would damage it to the extent of not being able to make boost (at the most it would only crack the exhaust manifold), my money is on an electrical problem because it has water in it. try unplugging a few things that may have gotten wet and spray them with rp7 to get the water out, but i would think that even with electrical problems it should still make some boost so as boosted_rb26 said check all your plumbing connections, the degreaser may have helped a hose slip off! perhaps!
thankxx heaps everi1..
it was the weirdest thing.. the car revs fine, it idles fine. it just won't come on boost...
anyway, i leave the car running for 10mins, 3 hours later took it for a drive and everything's back to normal..
so i still got no idea what was going on in the first place.. could it b because of too much water in the intercooler, because i sprayed i fair bit in there.....oh well, a lesson for every1, don't panic like me, i was getting instructions from this forum on how to remove the turbo... damn, could of gone wit a hi-flow
why the **** would you spray water in your intercooler?
because there's flies and sh.t in it, so i couldn't help it..............
anyway, just when i thought the car's back to normal again. the nex day took it out, it was fine for about 10mins. then it happen again, can't even go pass 2500rpm... surely some1 on here must of seen me on saturday ' a red r33 on tomkin highway moving slower than a donkey'....
so i went and saw a mechanic and found out the real problem.. water got in the engine.."where its got 2500 TWIN CAM NISSAN", somehow water got in there..
its all good now..hopefully... thanks everi1
Yeah I had a similar problem after my car got detailed and they OVER detailed my engine bay too :hellpisd: . I would get to boost and it would cough a splutter.
Water got in the AFM and the plugs. I pulled the AFM off and made sure it was dry. The plugs also had water on them - Ken from Hyperdrive told me to leave the car idling for like 10 - 15 or so minutes to dry the plugs out... it made it alot better.... but it took a few days of driving before everything was back to normal.
thats what i tried to say  :ufo:
chekck your afm first, before you pay him to do the engine.
thanks man but i didn't hav to pay anything.... i know the guy so i spoke to him and he said to take the plate off and leave it for a couple hours to dry... and i think its working, took it for a long drive 2day and everithing's fine
and Liz could of told me that earlier.. i was all stressed out Friday night and saturday morning... don't know if every1's feeling the same way but my car is like family 2 me, if something happens to it i can't eat n sleep probably...
Yeah what were we thinking...
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
