Was coming home about 12am last night.. and in the outgoing lanes of the M1 at about Robina area, I see one cop car on the side of the road with a couple of cops standing there outside the car. Thought that was a little strange, then 200m away *another* cop car with couple of cops standing there, which was getting even more odd.
THEN bit further on, I see about 6 cop cars with lights all on surrounding what to be what appeared to be an old 4WD..
Couldn't get a proper look, as I was driving inbound, but it was strange. Then a bit further on I saw about *another* 3 cop cars with lights on also heading that way.
So in the space of about 5 mins I saw about 10 cop cars!
It was truly something that appeared to be out of Canonball run!!
Anybody know what was happening??
:ufo:
NFI... But up my way, at about 12am, there was someobdy cutting sick in a V8 of some description... Can you "cut sick" in a 4WD?
More than likely someone with an outstanding warrant, who got pulled, and did a runner... The cops usually set up a cordon to the N, S, E &W...
I was on the way home from seeing kevin bloody wilson :) what fu#$ing ledgend!! when i saw 4 cop cars "chasing" an old blue van with 2 more cops on the way up the road and a pursuit car further up the road in Nerang
If its anything interesting it will be on the news tonight
strutto: yeah, it was a blue van! That's the one.
It was on the news actually and they had some footage. Apparently some drunk old guy was involved in a hit and run somewhere (I think the coomera thing was a different thing), and he was making a run for it. He was something like 3 times over the alchohol limit or something.
They used spikes to blow out the tyres. That must'a been what the other cops up front were doing at the side of the road. And the 3 cop cars further back must have been holding up all the traffic to stop them catching up to this guy. All makes sense now.
Wow - I got to see news in the making :) how exciting :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
