So i have decided to go for some 260/8.5mm Tomei ProCam for both inlet and exhaust.
But a thing i have never been able to get my head around is the whole differing inlet to exhaust cam duration on RB engines.
My understanding is that on the exhaust side you can normally get away by going for a slightly longer duration without affecting response a whole lot. On the inlet side though you have to be carfeul not to go too big adn subsequently affect cylinder fillign and response.
So the quesiton is can a cam / engine guru give me any advise on whether an otherwise std RB20 with a 420hp turbo make better use of 260/8.5mm lift in/ex or should i go 260/8.5mm lift inlet and 270/8.5mm exhaust.
Ive asked a few engine / performance places but im still hunting for a cam upgrade that will work nicely.
https://www.sau.com.au/forums/topic/57740-camduration-selection/
since rb20 doesnt have nvcs i would look at going for a setup which u usually see on rb26's.
most that i have seen have the same spec cams on both sides
but then again ive seen a few high hp ones with smaller inlet ones
SK i leave this to u (or someone else with a rb20)
btw roy for my rb30det ive put in tomei poncam inlet 256 9mm and hks 264 9mm exhaust cam
Roy I think the most success comes from extra lift rather than duration . Back in my Mini days I read David Vizards books which go into a lot of theory about heads and cam profiles . My interpretation is that generally the greatest port restriction is the valves themselves . Four valve heads breathe better than two valve ones because of the increased valve area . In standard form cams for four valve heads are pretty soft because they have extra valve area and tame profiles give good spread of torque over a wide rev range . With cam lift obviously a high lift cam has more average off the seat valve lift than a cam with the same timing but less lift . Full lift is only for a very short time so average lift probably dictates how well it all breathes . I see long period cams as a means of extending an engines rev range upwards , the higher it revs the less time is available to charge the cylinders on the induction stroke so holding the valves open longer means better filling . Ultimately long period cams have more overlap which leads to reversion at low revs and means rough running . The trapping efficiency is not there with longer period cam profiles . It is there with shorter duration profiles and the extra lift (average lift) from faster opening valves gives good breathing and good operating characteristics as well . There are people around like Ivan Tigh who can weld up some production cams and regrind them to suit custom needs , its an expensive process but may result in the ultimate short duration high lift RB cams .
Cheers A .
Butn want to stick with std valvespring and hydraulic setup so limits me to around the 8.5mm. Dont mind if i lose bottom end, dont have a lot anyway...but as long as i can make good gains over 4,000rpm then id be happy.
Perhaps i should stick with the 260s, though i was thinking that if i go a bit big in the cam dept as i have with turbo, then given time i would have some goodies that would work if i increased displacement
i had 260* 8.8mm lift ProCams in my CA19DET and there was a little low end loss, but screamed from 4500rpm-8000rpm, i wanted to go with TOMEI ProCams 256* 8.5 IN and 260* 8.8 EX cams, TOMEI valve springs and Gears on the RB i am planning on building next.
i am hopeing to lower the lowend/midrange grunt a little and i have been told this is a safe turbo cam set up, with my 260* pairs i had slight overlap dialed in... similar setups are poplular wiht the HKS cam kits as you can get different lifts/Steps with the same duration... but i too wish to keep hyraulic lifters.... so we'll see...
Was going to sticj with a rev limit of approx 8,000rpm, so again looking at making do with the std valvesprings.
If it all dies, or doesnt work, then i would most liekly grab an RB25DE head and do a 25/26/30 bottom end...whatever is cost effective at the time
I should add im in no hurry to change engines. I hope to see this engien last me a long time, but i would rather buy bits that work better then std on the RB20, even if they are not optimised on the RB20, and shoudl disaster strike then allow me to re-use...i went thru engine dramas earlier this year, and should history repeat itself i wont be repeating the mistakes of past:)
The old different cams question pops up again. I have generally found that when a subject keeps popping up, it is usually because there is no one RIGHT answer. I have tried angines with the same duration on inlet and exhaust and I have tried angines with different duration on inlet and exhaust. I can't say that one is better than the other every time. It depends on compression ratio, fuel, tuning, intercooler efficiency, exhaust design, turbo selection etc etc. There simply are too many variables to come up with a definitive answer.
With the hydraulic followers in RB20/25's I would be very careful with choosing a duration over 256/260. Particularly if you are not intending to change the valve springs. This becomes even more apparent when the boost exceeds 1.1 bar. The inlet valves tend not to follow the lobes on closing because the boost holds them open. This causes problems in the compression/combustion process (lowers the effective compression ratio). If you increase the duration, it just makes this problem worse.
My 20 cents worth:cheers:
Have to agree with the spiel about the stock springs Roy. It’s pointless going for baby cams due to little increase in power. Same story with big cams and stock springs, just doesn’t cut it when you are trying to pack in 20+psi boost.
Something like a RB20 needs 272’s all round with matched springs. Don’t **** around mixing and matching some custom combo when Tomei and HKS sell cam/springs ready to go. If you are going to modify it, taking half measures just won’t do when it comes to something as important as the head.
You have a good turbo kit so take advantage of that and the willingness of the rb20 to rev it’s nut off :) Get some biggish cams/springs and you won’t be disappointed.
I bought some Tomei 256 Procams for my RB25 rebuild... but they were delayed getting here and are now sitting on my floor while I run my new motor in...:P so I can't offer any thoughts... but soon I will do the 1000km oil change, dyno tune and throw in the cams, then maybe I can speak from experience... BTW the build quality of the Tomei product seems very good in my humble opinion...
I showed my engine mate who has shagged round with circuit cars for yonks the Tomei poncam specs.
He has seen my car on a dyno and immediatly pointed to the 260's (matched) "That's what you're thing needs!!"
As for the springs, I think I would put in as a "cna't hurt it" measure.
But as a Targa car, we are working within a lot of restrictive rules compared to improved production...
and for TT we need to chase 2500 - 3500 kw. Whoever says you don't drive off boost is kidding themselves... more mid range is an old bike trick. Helps carry corner speed and stops the buzzy agreesiveness from what should be suttle throttle resets.
Just a bit off, but we put all the gtr's behind one of our projects at Basky a couple of weeks ago. @ a mid 60, maybe only Whitey R34N1($150k+) and Greg Garwood, (X WalkerMC - NSW, Mines R33 Vspec - Cost = heaps) have gone faster...
So spend sensible dollars and you will go fast.
TT
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
