  • 3 weeks later...
I think series 8 compliance is between $10 - $12 K
C.A.M. (CANNINGTON AUTO MART) PTY LTD 08 9350 9696 and
E & M UNIQUE MOTORS 02 9648 2778 have compliance and it was spammed out at $5,000 plus tyres by Prestige but them having spare plates is another story, E&M Might.
This link will let you see who has what.
http://raws.dotars.gov.au/rawswebpublic/RA...AWPubSearch.asp
https://www.sau.com.au/forums/topic/57888-rx7-import/#findComment-1140798
  • 5 years later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
