Hey, i want the chrome front mount look but also improve cooling and its efficiency. These coolers are going for $320 + postage. Would this be hard to fit a R32 GTR? what would i need and what costs would i expect? and what other cheap alternatives could i take ?
- Polished Surface
- Core size 600x300x76mm
- Overall size 780x300x76mm
- Compressed air flow rate = 750 cubic feet/min, rated 750-800 max hp
- Working pressure = 35-40 psi
- Pressure drop = 2 - 5 psi @ 35 psi
- Hot air temp = 0-150°C
- Universal front mount fit
- Comes with mounting plates and bolts for fitment
- Core in fin (Bar and Plate)
- Hybrid OEM core
- 3" in/out end tanks
Thanks in advance
dude - hes takin the pi$$ out of you!! You want cooling properties - not aesthetics.
Its a good price for the FM alone - check out piping but, it can be costly.
You may be better off getting a hybrid kit instead.
:D
If you wanna spend the $$$ then invest in a well reputed japanese aftermarket FM.
You'll increase your cooling properties and will have a nice FM for your machine. (aesthetics and performance)
:D
:D
Until he has 300+kw, a new FMIC is a waste of money (unless there is something wrong with the current one).
LW.
leave it black, it works better heat wise by a few degrees and keeps the cops away.
that hybrid is no better than factory.The terms 'cheap alternative' and GTR don't go together very well most of the time.
I'd say a cheap alternative is a 600x300x110mm trust intercooler for when you upgrade the stock turbos to some 2530's. Then you can add some injectors, Power FC, bigger fuel pump,better clutch and start saving for the rebuild that will be coming sooner rather than later once you go for the extra power with an old motor.
Having said that I think if you would like a nice looking shiny intercooler there is nothing stopping you from getting the factory one polished. That is a cheap alternative my friend.
Maybe he wants to get 300+kw??? He did also say he wants to " improve cooling and its efficiency" !!
Sigh...
Forget what i said mate, here is what you want to hear :
Piss that stock cooler off for starters and get a Hybrid kit.
If you want to spend over 5 x more than what you had in mind, than get a Japanese brand. Maybe you will put a T78 on it one day and will really need it.
Who am I taking the pi$$ out of now...?
:slap:
Sigh...
:slap:
5 x more!! damn! Maybe if he flew over to japan and got it himself!!
A decent trust kit isnt that dear!! :D
edited
You are taking the piss out of all of us that have a dream or a goal my friend.
From greenline.co.jp :
TRUST GReddy Intercooler Kit
294 x 600 x 115 mm.
¥136,868
@80 cents per Yen, that is $1710 in Japan.
That, according to my maths, is over 5 times the $320 he had in mind.
Now, feel free to correct me, as you seem to enjoy doing.
:bonk:
Listen mate, the last thing I want to do is to turn this into a slanging match.
FYI, I am not offended, I am merely trying to correct you; although you are coming back with a different angle every time.
If you like to paddle in your canoe upstream, that is fine. Just know that there is a strong current in here.
performance.. is coming second at the moment to haveing reliability and clean body.. but it was only a suggestion.. dont just go around and say shit hes looking for cheap etc... if theres no point upgrading or degrading i wont do it.. i would rather save the $$ and get a trust one latter on..
i wont lie, i think a nice big shiny intercooler looks good.. and looks to me are important.. but to others they couldnt give a crap if the kits all hanging off and there no back seats etc.. as long as there car is going that bit faster and i have not 1 thing against these people.. god i almost envy them.. working a car aint for the faint hearted..
thanks for your comments people.. i saw the rh9 cars all running hks turbos etc and trust front mounts ? is that tellling me something about performance of trust intercoolers??
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
