  • 4 weeks later...
Power Restiction For P-Platers In Vicroia: 125kw/tonne
From May 1989 to 1991...
R32 Gtst Type - M Sedan (Manual)
Power:158Kw
Weight: 1290kg
Power/Weight Ratio: 122.48062015503875968992248062016kw/t
Under Power Restictions
R32 Gtst Type - M Sedan (Automaic)
Power:158Kw
Weight: 1310kg
Power/Weight Ratio: 120.6106870229007633587786259542kw/t
R32 Gtst Type - M Coupe (Manual)
Power:158kw
Weight:1260kg
Power/Weight Ratio: 125.39682539682539682539682539683
Over Power Restrictions
R32 Gtst Type - M Coupe (Automatic)
Power:158kw
Weight:1280kg
Power/Weight Ratio: 123.4375
Under Restictions
I worked out that from an RB20DET which produces 158kw that to be spot on the p/w ratio the weight of the skyline would have to be 1264kg's... so: If the skyline is under 1264kg's then it is OVER (Illegal) the p/w ratio, but if the skyline is heavier than 1264 it is UNDER (legal) the p/w ratio. I used to think if the skyline is an r32, and its a gtst then its legal but the one exception is for the 2 door 1989-1991 gtst wich weighs 1260kg. But, from 1991-1992 the weight increased to 1320kg making it legal. BUT, does the restriction include the weight of the driver, because the 89-91 2 door gtst is 4kg's under...
https://www.sau.com.au/forums/topic/58075-125kwpt/#findComment-1150736
  • 3 weeks later...
it's based on factory quoted output, and does not include weight of driver. The p/w ratios you have there are what they use.
Also note, that the only skyline on the vicroads list of restricted cars is the '32 GTR, because it was the only skyline released on the australian market.
Most cops don't know that 33 gtst's are not legal for pplaters - though i'd imagine TMU cops would have a fair idea.
As mentioned before, maybe you should have found out if you could drive it *before* buying the car. Did you have a question, or were you just whinging?
You could drive it on p's, but just keep in mind if you make an insurance claim, the insurance company could say that you were driving unlicensed. as you wernt licensed to drive that particular car.
The only way i can think of to get around that rule, would be to buy an R33 GTS, and put in an rb25det.
https://www.sau.com.au/forums/topic/58075-125kwpt/#findComment-1182396
How Many Times Does It Have To Be Said?!!
It Is Factory Weight... Taking A Shit, Taking Out A Spare Wheel, Or Sticking A Sticker On It That Says 2000kg Doesn't Make You Any More Legal. And the cops won't accept that for one second either.
Get Over It!! You Are Not Supposed To Be Driving These Cars in lovely victoria.. And Cops Will Punish You If You Do. You'll Be Selling Your Car Before The End Of Your P-plates Anyhow... if it even survives that long.
https://www.sau.com.au/forums/topic/58075-125kwpt/#findComment-1183278
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
    • Infiniti US are teasing a manual Q50 as a way to refresh a (very old) model. https://torquecafe.com/manual-performance-sedans-arent-dead-yet/ Can't be too technically difficult given the Z has the same motor with a manual gearbox......here's hoping there is a JDM version we can import here, that would save me a world of headaches
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
