  • Replies 63
Lots of water on morsehead, past russell and duntroon also just heard there is a 4 car pile up at the huge roundabout near commonwealth bridge. I thought my windscreen was gonna break when a truck goin opposite me dumped a heavy load of water as he went past on the overpass to monaro! Drive safe everyone., tis hard to see
I just drove from Belco to quangers and back and it's absolutely drenched everywhere. it doesn't look like this will ease up anytime soon.
just be careful on the roads, i had a 4wd almost go up my arse, but i saw it coming and just edged into the intersection to let them have a bit more stopping distance.
AWD does help in the rain though, my old skyline would have been all over the place on some roads.
hey canberra peeps
I live in wagga and a massive hail storm came through earler... Just heads up. My car picked up a few little dents before I got in inside.. Not happy.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
