11.7 and 116 mph = ~250 rwkw (that's on a roller dyno)
If it is a hub dyno, add 15 rwkw (no wheels or rollers).
265 rhkw (rear hub kilowatts)
Note no mention of camshafts:cheers:
So what sort of camshaft/timing do you think this engine setup has. I would be surprised if this is radical, may be just an improved standard setup
Turbine
sk, the hr31 irs is very difficult to control. No matter how much wheel alligning you do the design of the irs still see's the rear tyres half of the ground. Every import 31 has this problem.
Took it for a proper drive for the first time since I got the car back from the tune, and its developed a nasty missfire as soon as it hits boost. Im thinking ignition (again) since the back of the car was covered in fuel when I got back... time to bring the plug gap down yet again.
sk, the hr31 irs is very difficult to control.  No matter how much wheel alligning you do the design of the irs still see's the rear tyres half of the ground.  Every import 31 has this problem..
This one works great;
They are no more difficult than any IRS with struts. The trick is to find out exactly how much it is going to squat, I use a video camera and cable ties on the shock shafts for that. Once you know, then you can simulate it on the wheel aligner by jacking it up and down with the rear springs out. You remove as much dynamic camber change as you can with the offsett bushes. Then you set the static camber so that the tyre contact patch is optimised at full squat. It's pretty simple really.:(
we aint all on race team budgets remember :P
You're kidding, right? Our budget wouldn't buy the paint job on an Autosalon car. It's not about how much you spend, but what you spend it on. An example;
Hey mate, for $700 I can get you lots more power, enough to improve your 1/4 times by 0.5 sec. How fast would you jump? :wassup:
Compared to;
Hey mate, for $700 I can do a wheel alignment that will improve your 1/4 times by 0.5 sec. Now how fast would you jump? :kick:
We have to make that sort of decision all the time, what do we spend the limited money on to get the best result. Engine power bragging rights are pretty worthless, it's all about how long it takes to get from the start of the race to the end of the race.
:cheers:
Hi all , have to agree some mods forced by limited budgets can be very effective . Some time back I had DR30 IRS grafted into a Bluebird and remember thinking the crossmember bushes were too soft . The budget fix was to drop the rear end out and fill the gaps in the rubber bushes with of all things stickerflex . This stuff has very similar consistency to the rubber and is the cheap way to get a "works" style bush that still has some compliance . I have seen a few HR31 IRS rear ends and their X member bushes are REALLY soft . This will not help with tramp or alignments .
I got the car back today and it did 271rwhp@16psi .It was'nt tuned in kill mode but it's safe.I used to get like 90 knock all the time with the old tune but now the most is 35 and thats raping it.300 would be good to have so I'll see what happens.
Nice, it wil make 300 easily with 19-20psi:). How does it feel on the road?
Can you post up a link to your dyno sheet (and mine.. I lost the link), be interesting to see how much better your power curve looks.
HKS GT2535 turbo
Stainless exhaust manifold
R32 GTR intercooler
Z32 afm
Apexi pod
R33 GTR injectors
Greddy profec b boost controller
3inch dump pipe,3inch mild steel mandral bent exhaust
Bosch 040 fuel pump
Nismo adjustable fuel regulator
Apexi PFC
16psi
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
