its internally gated...and i dont have injectors yet, but thats next on my list. the guys who r doing for me (race solutions and hitman in penrith) asked me the same question bout injectors, and after i told them i havnt done them yet they said theyll see how far they can push the stockies....im hoping to get injectors done after christmas :(
Without injectors done forget about joing the "260kw" club. And if its a TO4 with internal gate have you got a pic of it?
When you said turbo rebuilt to TO4 specs did you mean your stock turbo supposedly built to TO4 specs or another turbo that you have purchased?
oh and im not expecting to get above the 260 mark without getting other stuff done, meaning mainly injectors (which is my next project) and a fuel regulator...i was simply stating what i have gotten done thus far, so please dont treat me like an idiot...as im not one, with what i have done so far, im realistically hoping for 220-230 atw kw, just thought id make that clear...thanks
Edited by R32_GTS-4
so is 220-230 theoretically possible with standard injectors?
no, stockers rated at 270cc's are crap for 240 HP at the wheels, they will be maxed out at that power.
100% duty cycle is not your friend, you should never run over 80% for safteys sake.
hell, im taking out my 550's and going to 720's just to have a low duty cycle, and thats with about 450bhp.......
Mine were hitting 92% duty for 176rwkw. Keep reving it past peak power and it required 100% duty to hold a 12:1 AFR.
They were slightly dirty as cold starts would see it stumble slightly.
Depends how happy the dyno is if you make 220kw with std injectors.
All though at the dyno day there was an R32 running stock ecu, stock airboox, exhaust, fmic, HKS GT2530 @ 1bar. That made 178rwkw.
Unsure if injectors were at their maximum, it now requires an FCD to make more power.
Edited by Cubes
maybe past 240hp at the wheels. Thats where I'm at with the stock Rb20 injectors @ 14psi with the stock turbo.
That dyno is either very happy, the injectors aren't really standard or the fuel pressure is way above standard. There are no miracles in engines, including fuel injectors.
:angry: cheers :P
:) cheers :)
Well not a happy dyno but I do have a 255lph fuel pump blowing past the stock regulator :)
I recently had my GTR injectors flowed.
Base fuel pressure set was 40psi.
@ 100% duty they flowed 474-480cc
@ 80% duty they flowed 384-390cc.
So theoretically, say the GTST injectors are 270cc's.
270cc's * 0.8 = 216cc (80% duty).
Isn't the old rule of injectors 1 cc per hp. 216hp.
Or is that 1cc per hp based on 100% duty flow i.e 270cc @ 100% duty makes 270hp at 80%duty.
Kind of messy but hope it makes sense. :)
Stock RB20DET running 14psi with a tuned ecu (PFC) on the dyno's I run on generally make spot on 170rwkw.
Edited by Cubes
Hi R32_gts-4
550cc will get you the rwkw your after Matt tuned mine with 550 and there still on standard presure and im running 238rwkw on his dyno with other mods to though but if your running a to4 as i was i think u might be battling i had mine rebuilt twice and it still dont flow enough runs outa puff at 6800rpm and its rated at 500hp
Cheers Peter
Edited by legend01
hey thanks for the info guys...i have another question, does anyone know the part number for bosch 550 injectors, i called their inquiry line and they have no idea, great help they were haha
also does anything need to be modifyed to fit bigger flowing injectors? i heard somewhere that u need a higher impedance, i think? is this right, or am i getting told crap??
thanks
thanks
hey dude, I have a set of Nismo 555cc injectors in my GTS4, they are straight fit just plug in and go. Don't worry about some obscure help line, just go to a site sponsor or nengun (where i got mine) and get them cheap and the best quality around.
I've had my 555s for 3 years now and once tuned on a RB20 like you then idle and economy is perfect. Can't go wrong! :)
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
