its internally gated...and i dont have injectors yet, but thats next on my list. the guys who r doing for me (race solutions and hitman in penrith) asked me the same question bout injectors, and after i told them i havnt done them yet they said theyll see how far they can push the stockies....im hoping to get injectors done after christmas :(
Without injectors done forget about joing the "260kw" club. And if its a TO4 with internal gate have you got a pic of it?
When you said turbo rebuilt to TO4 specs did you mean your stock turbo supposedly built to TO4 specs or another turbo that you have purchased?
oh and im not expecting to get above the 260 mark without getting other stuff done, meaning mainly injectors (which is my next project) and a fuel regulator...i was simply stating what i have gotten done thus far, so please dont treat me like an idiot...as im not one, with what i have done so far, im realistically hoping for 220-230 atw kw, just thought id make that clear...thanks
Edited by R32_GTS-4
so is 220-230 theoretically possible with standard injectors?
no, stockers rated at 270cc's are crap for 240 HP at the wheels, they will be maxed out at that power.
100% duty cycle is not your friend, you should never run over 80% for safteys sake.
hell, im taking out my 550's and going to 720's just to have a low duty cycle, and thats with about 450bhp.......
Mine were hitting 92% duty for 176rwkw. Keep reving it past peak power and it required 100% duty to hold a 12:1 AFR.
They were slightly dirty as cold starts would see it stumble slightly.
Depends how happy the dyno is if you make 220kw with std injectors.
All though at the dyno day there was an R32 running stock ecu, stock airboox, exhaust, fmic, HKS GT2530 @ 1bar. That made 178rwkw.
Unsure if injectors were at their maximum, it now requires an FCD to make more power.
Edited by Cubes
maybe past 240hp at the wheels. Thats where I'm at with the stock Rb20 injectors @ 14psi with the stock turbo.
That dyno is either very happy, the injectors aren't really standard or the fuel pressure is way above standard. There are no miracles in engines, including fuel injectors.
:angry: cheers :P
:) cheers :)
Well not a happy dyno but I do have a 255lph fuel pump blowing past the stock regulator :)
I recently had my GTR injectors flowed.
Base fuel pressure set was 40psi.
@ 100% duty they flowed 474-480cc
@ 80% duty they flowed 384-390cc.
So theoretically, say the GTST injectors are 270cc's.
270cc's * 0.8 = 216cc (80% duty).
Isn't the old rule of injectors 1 cc per hp. 216hp.
Or is that 1cc per hp based on 100% duty flow i.e 270cc @ 100% duty makes 270hp at 80%duty.
Kind of messy but hope it makes sense. :)
Stock RB20DET running 14psi with a tuned ecu (PFC) on the dyno's I run on generally make spot on 170rwkw.
Edited by Cubes
Hi R32_gts-4
550cc will get you the rwkw your after Matt tuned mine with 550 and there still on standard presure and im running 238rwkw on his dyno with other mods to though but if your running a to4 as i was i think u might be battling i had mine rebuilt twice and it still dont flow enough runs outa puff at 6800rpm and its rated at 500hp
Cheers Peter
Edited by legend01
hey thanks for the info guys...i have another question, does anyone know the part number for bosch 550 injectors, i called their inquiry line and they have no idea, great help they were haha
also does anything need to be modifyed to fit bigger flowing injectors? i heard somewhere that u need a higher impedance, i think? is this right, or am i getting told crap??
thanks
thanks
hey dude, I have a set of Nismo 555cc injectors in my GTS4, they are straight fit just plug in and go. Don't worry about some obscure help line, just go to a site sponsor or nengun (where i got mine) and get them cheap and the best quality around.
I've had my 555s for 3 years now and once tuned on a RB20 like you then idle and economy is perfect. Can't go wrong! :)
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
