Hi Guys
just got back the results of the flow tests between the rb20 standard manifold and the hks cast manifold will mark these 1 to six front to back
standard HKS cast
1. 159.7 170.7
2. 162.4 166.6
3. 160.7 178.7
4. 150.6 183.6
5. 149.9 182.2
6. 173.3 184.7
As you can see all flow pretty well and a marked inprovement over standard but you'll have to draw your own conclusions if the flow improvement is what your after for the cost although afe did state the these are very well made the casting quality was some of the best his seen and flow extremely well for a cast manifold a worthwile investment over standard and he was kinda wondering why they stoped making them . One other thing he said to me was not to tell anyone you have one as he said you'd probably surprise some people with the way the car goes even in standard form to say the least i think it impressed him and that statment coming from someone who deals with these sorts of things daily makes for an impressive statement
Cheers Peter
So who can tell me the internal diameters of the Rb20DE, RB20DET, RB25DE, RB25DET and VG45 throttle bodies?
I figure the Mitsu boys love boring out their throttle bodies for a few extra kws...
And has anyone looked at the alignment of inlet manifold to the head? I figure if the extrude honing isnt too expensive then i will get the inlet manifold flowed, match port it to the head, throw a bigger throttle body on it and see how it goes....
I looked at the inlet manifold porting to the head when i fitted my motor up together. Basically there was sfa difference. I just took out the 1 or 2 mm here and there that was the difference. I was suprised how well the std nissan stuff was matched Roy. Using the gasket as a template and a rotary tool it took only like a few mins to get it spot on...
Extrude honing the inlet would be good as well as the exhaust manifold. As far as i know the tb is about 2.5" (same as ic piping/afm ~80mm) and the VH45 is about 90mm (same as the afm)
Edited by Bl4cK32
Several years ago (there is thread on it), we flow bench tested a standard RB20 cylinder head, inlet manifold plenum and throttle body up to airflow sufficient to make 500 bhp. It showed no improvement when we removed the throttle body completely. So fitting a larger diameter throttle body is a waste of time and money until at least 300 rwkw is reached. It maybe even more than that, we stopped testing at 500 bhp.
:) cheers :D
Funny you say, the new baby is shooting for 300-330rwkws, so whilst its all apart may take the time for a small improvement here and there
i take it your not doin that on std internals? I was thinking of trying a hks 2835 pro or hks gt-rs and see what sort of number i can pull with a low mount
hopefully soon we'll see how a HKS Fcon V Pro will perform on a RB20 minus AFM...
already seen. performs well, thats IF you can find someone to tune it. atm i'm waiting on a tuner over here in SA that says he's trying to develop some software for it. other than that its only BD4s that can tune them AFAIK.
as soon as i can get it tuned the turbo will be downsized.
KKK-K27@12psi
KKK-K27@12psi
bd4's is the plan
hope the dont shut down! lol
fwiw hks gt3037 = gt30r.
i cant wait to get my engine back together, with proper compression (175psi vs 140psi) the turbo should come on harder and faster with better response.
least i hope it does.
Without a doubt it'll be alot faster.
You can get an 044 to fit internal - I've got 1 in my '33.
Bit more stuffing around but possible.
so i can get the 044 to be an intank pump? would it be just the same as installing the 019? the 019 was a fairly long pump...im just asking as everywhere ive researched everyone keeps saying its an external pump...so im just clarifying
thanks
chris
I have a q45 trotthle body right here. Its 85 mm on the inlet side and 83mm at the valve side.
Was planning to use it on my rb20det after the head is flowed and a custom manifold is mounted, but maybe its a bit to big. Maybe trade it for a rb25 body orso.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
