Max power on mine is made at around 6,000rpm and rev limiter is set at 7,000rpm. Power doesnt dive it just slowly tapers down.
I agree with Roy about wringing the first two gears a bit more but my car is all over the shop in first and second and I always am bouncing off the limiter unintentionally.
I need to improve my driving skills/suspension/tyres before I will bump it higher.
post-7066-1142056038.jpgOk after a long wait car is finally up and running again although still with restriction issues will post the graph and maybe get a bit of a disscussion going on possible causes tuner is still leaning towards exhaust as it is pretty quiet the other is inlet track somewhere anyway u will see by the power curve that there is a problem I just gotta find the damn thing
cheers Peter
Edited by legend01
Thought about doing trhat but it wouldn't have told me anything as anyone that drops there exhaust will make more power wheather the exhaust was restrictive or not but thanks for the suggestion
Peter
Peter
I wouldn't be complaining with that power level anyway. :/
Can you remind us what kind of turbo you have and bottom end?
Those are some mighty high intake temps! where do they stick the sensor?
It will make more power without the exhaust as any car will any exhaust is a restriction we did try this and it made a heap more power but that was when I was maken 238rwkw since the engine will flow exhaust gases faster with no exhaust air into and out the engine it not pinpointing where the flow hold up is but i think a newer exhaust has to be the first step as the intake side of things is suppose to be good for 450 hp well thats how it was explained to me
Interlooper the bottom end is stock engine has only done around the 65000ks mark as ive had the haed of for porting bores looked brand new so it was left alone turbo is a garrett GT3040R
update
from information gained it appears 3" exhaust will not flow fast enough above 250rwkw so just bought a 3.5" cat back exhaust will fit that and then try tuning again c if that fixes the problem
Cheers Peter
Edited by legend01
update
Cheers Peter
what brand exhaust did you buy? or is it a custom one?
ok the engine is nearly done, it might be in on saturday morning, i have come accross a problem, i have one washer left over, i think its from the bottom end, its a silver washer with a tapered edge, its about 15mm across.
anyone got an idea where its from.
well its nearly all done, just a few more bits, this is the engine that i hope to crack 300RWKW+ with. will it happen, u bet it will. its taken so long and its only a week or so away from dyno run in and full power tune.
well here it is, the engine ive been building, this is the one i hope to crack 300RWKW+ with, its been so long and now its only a week or so away from the dyno run in and full power tune.
Edited by boostn32
Yo everyone, just wondering if any of the RB20 owners with over 240rwkw have had engine failures or mechanical troubles when used in a circuit/drift enviroment? reason i ask is my rb20 just made 258rwkw @18psi (mods are listed here:) http://www.skylinesaustralia.com/forums/in...ic=103095&st=20 but the tuner recommended i only run with around 1 bar not because the tune wasnt safe, (it was detonation free at 18psi) but because the sheer mechanical strength of the motor could not take that sort of power continuously ie lots of revlimiter action in drift. Any opinions would be greatly appreciated, especially from roy & other RB20 heros who use there cars in circiut or drift where are they are given a pounding.
Cheers.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
