there is no better way to keep an engine or gearbox in one peice than buying a spare and keeping it in the garage. invariably you wont need it!.
I had the same thing happen with my GTI-R. I bought a spare box as they are notorius for breaking them. and sure enough I never needed it. :huh:
The rev limiter was set to 7800 which i used to take it to often in first 2 gears.Low boost was set at 14 psi for everyday driving that said though it was more or less just a weekend car and I only got to drive it for 9 months b4 it went all outa shape but every time it went out boost got wound right up at the very least twice during each outing so fairly often Id say just not for long periods.
Actually same oil as you though cant remember what is was though I do remember looking up one of your old posts to suss out what oil you were running as I new you did a lot of track days
cheers Peter
Stock RB20DET internals, HKS 2530 turbo, 550cc injectors, fuel pump, dump/xorst, fmic. Pulls 220 rwkw on dyno and blows 6.0 ltr SS holdens off the track.
Runs 18psi boost all day long.
Dyno report attached.
std internals rb20
34 gtr injectors
big fuel pump
nizmo fuel reg
trust td-06 20g 16c turbo (big spec)
rb25 stock exhaust mani
china cooler
EMS stinger ecu (map sensor)
profec b spec II
tial 38mm gate
3 1/2 inch cat back
STANDERD cat!
335hp atw at 19psi on ovaboost dyno, 4 days after the tune went on shootout mode and made 330.9 at 19psi
1350 ft/lb torque
http://i15.tinypic.com/2d00zly.jpg
booked in for a retune next friday because the stock cat is replaced with a decat pipe (stock one melted and wouldnt let me boost past .9 bar)
that afr is shocking.. definatley more power to be had there
std internals rb20
34 gtr injectors
big fuel pump
nizmo fuel reg
china cooler
profec b spec II
tial 38mm gate
3 1/2 inch cat back
STANDERD cat!
1350 ft/lb torque
it did the 330 run at a show, they had the dyno (2 dynos) setup in a tent back to back with a divider wall, a few cars had feedback in the afr charts becuase the probe was so close to the wall...
its tuned better than that chart says :laugh:
I will get a printout in RPM for the next tune to show how laggy the thing is, 5k it hits full boost :)
16c is referring to the exhaut housing size. It seems the turbo is the same as mine except it has an A/R exhaust housing off an RB25 or a 13B.
Grab a 8cm or 10cm housing and you will be making over twice the power at 4,200rpm then you currently are.
ran it up again on a shootout mode approved dyno so i could get an rpm printout, i left the factory rubber inlet pipe on for the run, once it hit full boost(24psi) it sucked shut so it wasnt a full power run. biggest limiting factor atm is that damn pipe but once we get time we'll knock a hard pipe up
she cracked 366.3 at only 5500rpm but as u can tell from my sheet above it has a slight incline so 370 might have been acheived
afr's go into the 9's once she hits boost :S but i want it safe so not to worried about that
the dyno operators say 400hp is very possible if it gets retuned back into a leaner ratio but like i said im happy to keep it safe where she is :D
dont have a copy of the sheet atm but heres the rpm/power ratio
2500 rpm = rwhp 54
3000 rpm = rwhp 63
3500 rpm = rwhp 81
4000 rpm = rwhp 117
4500 rpm = rwhp 198
5000 rpm = rwhp 342
it actualy boosts earlyer than i thought, full boost by 4700 and cosindering the power/turbo its pretty good
Another track day done and dusted. Im making a bit more power then previously and it feels like it to. Pulling really hard. I think i was running about 16-17psi.
Engine did not skip a beat all day and still is not breathing a drop of oil at 230-260rwkws. 10,000kms in and a general inspection of the motor is its still in perfect health and not showing any signs of trouble. So next track day in a few weeks is Sandown where the extra bit of power will help so will be running about 19psi.
I will try and get a vid up...i cant believe how well it now pulls in 4th and 5th gear. You can see on the early laps im coming out of corners going for the next gear and im going for where the lever would be if its in 3rd only to find im in 4th and need 5th. Its amazing how well the thing pulls in the top end....lol, the TD06 is no longer for sale. TD06 for life :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
