hey all just in the middle of my rb20det build, once complete will have it dynoed and take it to the creek, just keen on getting some of your estimates on how much power i will have with,
to4e top mount
38mm external gate
z32 AFM
550cc injectors
bosch 040 fuel pump
plazmaman plenum
ems 8860
will be running her at 16psi any feed back will be great thanks
Had a run at wsid 2 weeks ago first run though I broke the hicas lock . Couldnt figger out why the car felt like it had egg shaped tyres ,One wheel was flappen in the breeze steering itself,Was my first run in 18months so still gotta get some more practice in yet but still ran 12.5 looking for a better pb this wednesday hopefully .Second run I bogged it of the line only ran a 13.4,so still go some work to go b4 I get there, only had the 2 runs cause I found the hicas problem then so called it a night
Cheers Peter
what mph?
thanks
h
109mph,Jap32 what power are you running ,that would give us a bit more of an indication of what sort of times you might run though there's alot of other factors to take into account like tyres as well .Have you got an engine bay pic with the plazmaman plenum on thinking of putting one of these on as well
cheers Peter
legend01 haven't got it all together yet hopefully will be put together this weekend then i gotta get the ems ecu put in and dynoed, just wanted a rough estimate on what power output i might be getting with all thee upgrades?
  • 3 weeks later...
Well guy's I've cracked it at last had 4 runs at wsid last night three I stuffed of the line one I hooked up properly still think I might get it down lower yet but very pleased with the time,Check it out 1 rb20 11 sec pass
R32 - Rb20det
GTR injectors
Wolf 3d ecu
500hp walbro fuel pump
Original hybrid gt spec cooler kit
full 3inch exhaust in highflow cat
Ces dumppipe
standard rb20 turbo
dyno Tuned and boosted to 14psi - made 160rwkw and ran a 14.1 on baldish street tires
Car is currently in the shop getting:
GCG highflow Rb20 turbo
Split fire coilpacks
Xtreme HD clutch
Retune and more boost (I think 16psi maybe 18)
Anyway one know what kind of power to expect, Id love to crack the 200rwkw mark but judging by alot of other r32's it seems pretty hard
thats absolutly awesome man congrats!! same mph i run so thats boosted my confidince in improving :rofl:
are you using a 25 box?
Hi AD4M
yes I am mate standard box wouldn't last long with that abuse,and I've run a higher mph than that but stuffed the launch so there's hope 4 me yet
cheers Peter
Nice run Legend, well done.
Going to a drag day in late October and hope to crack 12s. In theory could possibly get low 12's/high 11s but the R31 suspension is not a slick unit and the driver is hopeless lol.
Last time out with very bad tyres ran 14s @ 109mph with 235rwkw.
Have 280rwkw this time and some ET streets to us so if I can drive it well enough should hopefully run something respectable.
Stock turbo as well hahaha!!!!!!!!!
Hi Guy's
Thanks for the support its great.
jnr32r...I'm launching at around 5500 to 6000 rpm.
FATGTS-R ,with the power you have I dont think you will have any problems getting low 12's high 11's as for the suspension ,I dont think that will be too much of a problem as I run really stiff suspension no squat at all im told of the line.I'm running M/T street radials as well and am still playing with air presures atm but that run they were set at 14psi and hooked up well
I do hope in the future to improve on my time maybe low 11's would be good ,diff is real noisey after wednesday night so maybe time to stick the gtr diff in.Its just the start of the season so I've got plenty of time ,good luck to all trying for better times I'm happy with mine for the time being
Cheers Peter
Awesome, awesome, awesome work Pete!!!!!!!1 :D Well into the 11s :worship:
Well i just completed another Dutton Rally where the car saw 1.1bar on Friday, then 1.3bar all Saturday and Sunday. Car ran faullessly with not a drop of blow by and would have been making 260odd and driven in anger. My co-driver was turning it in for me by using the rev imiter in 3rd gear for shifts to 4th coming onto the straight at Sandown. Rev limit was changed throughout the event, generally between 8,000 and 8,600rpm. Fingers crossed there is some decent footage of all the limiter action
And aweosme work Pete! :(
I am running a to4e p-trim turbo with v band on my r32 rb20det gtst
Walbro fuel pump
sard fuel reg
3 inch turbo back exh
Standard computer
Standard internals
Standard injectors
It ran over 240 rw kw on '98 Tuned to 236.7 Rearwheel kilowatts at 14psi. Its laggy but when its on,its on.
Want to run more boost but injectors are maxed out. Anyone got any suggestions for injector upgrades so I can run more boost? Im after bang for minimal bux if you know what I mean. Series 5 rx7 ones ??
Edited by dirty232
