It'll happen, just a matter of time.
bummer for motor sport,
Don't worry someone will build another one, only prob, it will be somewhere west of the snowy!!!
I heard Woomera has some space!?!!?!
lol it only closed about 10 years ago!
Lets face it OP will close, leaving us with Eastern Creek at top dollar or Wakefield 3 hours away. And EC is a borin track.
so...GET OUT THERE and ejoy it while it is still around. OP Grand Prix circuit is by far the most interesting in NSW, its one of the old style tracks that just go up and down as the land did....very challenging in places.
Ahh Amaroo ... those were the days !!
Who remembers "Liverpool City Raceway" ?
I DO! i remember going to watch the sprint cars there when i was a little kid. I always seemed to remember it been better than parra speedway.
You can buy a house on the main straight of Amaroo these days. Damn progress.
Amaroo park was a real loss, and can see Oran going the same way with NSW land prices being what they are:(. I should have taken my old Valiant to Amaroo, it looked a great little track with touring car races always action packed.
We will always have Punt/Bells, and with mobile phones/000, the firies and ambos will never be far away:(
  • 3 weeks later...
I heard 5 years til she closes, read this in a Motorbike Mag that they are developing the track site and a dairy farm to open new residential area...
Aparrantly the 2 owners stated that they would continue to back australian racing and that they will/might open another track elsewhere!
hope that goes ahead!
anyone remember Amaroo Park?
Amaroo park was tops. My best friend in high schools dad used to race HQ holdens (and open wheel formula cars before that) there. Was an awesome track. Glad I got to go there while it was still around.
It will be a shame to see OP go, but I'll most certainly be out there in the GTR before it does.
Richard
I use to ride my push bike around amaroo park back when I was a kid :) Damn hill just after the start line use to kill me hehe
hahaha classic, that was the only I ever did laps of Amaroo too :)
much easier in a car I bet
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
